XPlay (Android)
What Android version do you have on your device? It works only with Android 5+ devices
Android TV 8.0
Try direct link
Link to the app: Get it on Google Play
Same…
Is it the new update or you still have not got it? Thanks a salu2.
I guess it will be released tomorrow evening
Gracias salu2.
the new version has been published.
What’s new.
added: German language - I want to say huge thank you to @Speziald for help with translation!
added: Home Users
fixed: HLS mode for transcoding
fixed: EAC3 played without sound
fixed: several minor UI issues
There are no too much fixing in UI in this version. Because there were issues with playback.
So In several next releases will be only UI changes.
Link: Get it on Google Play
You´re Welcome.
There are still some words that have to be translated i guess and maybe someone else got a better translation for a word or sentence, then just let him/us know :slight_smile:
Hello @DironDir
Thanks a lot for the Home Users Features !!!
Great job !!!
You are welcome :slight_smile:
I need to think…
Are you from Russia?
Yes, from Russia.
Okay, I will check.
Maybe something is wrong with publishing settings
Have you tried the last update? Is everything ok?
Thank you first for your effort and constant improvement of the application. I will tell you my experience with the last update, in the tested movies it works correctly now with sound ac3, my problem is that if I choose external player, share, for example vlc now it does not work for me, thanks.
What do you mean by characteristics of home users?
There are many unknowns: what do you try to share? Send me a link to download exactly your video.
A can take a look but I’m not the vlc’s author to say much about why it doesn’t work. So I can only check what XPlay tries to share.
You should have Plex Pass to be able to use Home Users.
Here is a description what it is: https://support.plex.tv/articles/204234323-creating-a-plex-home/
In several words - you can create several users with different rights to access content
Next version has been published - 1.0.18.
Navigation changes:
  • Press Back in the content list to open Main Menu
  • When main menu is open - last selected element is focused
  • Press Back during playback to hide controller
Others:
  • improvements in content scrolling
  • icon is shown for user in top menu
