XPlay (Android)
Hi i didn’t know there was an update already. will check it out tonight thanks.
Sorry for the translation I, I wanted to say that by choosing to watch the direct movie with any external player that I have not opened and before the update if, but now it opens almost all without resorting to the external player. If I have Directplay and I the movie transcodes audio or video???, thank you.
Maybe I didn’t get the question but in direct play mode there is no audio\video transcoding
Perfect thanks for the clarification and excuse my ignorance.
Well I keep doing tests and in this last update all the movies and series that I test works correctly, but what is my surprise when entering the main menu, where this general, video audio … just lets me enter and show in general , I can not enter video to configure it so I do not know how it is configured.
@PEDRODOKY
I’ve released a new version. It will be ready to update in about 30 minutes.
Try update the app and let me know the result.
If you don’t see any difference - please, will provide a screenshot to show what is wrong.
@DironDir
Can you add french translation to the app ???
:wink:
@DironDir thank you for all your hard work and many bug fixes. Do you have a date/time scale on the TV episode fix?
Just find it hard work having to go directly to the episode to play rather then continue from the home screen.
Gordon
In this screen I used to let me choose the options in music video player, see data account and about, but now I can only access the options of general and reestablished predetermined, which can be due if I could do it perfectly before? thanks a salu2.
Same here, I can’t access any other part of the settings only General.
Also I have to login every time I launch the app now, before it was just once to login which is much better just like plex.
Hi is the updated version on the Play Store?
Thanks for pointing. Indeed there was a problem…
I’ve released an update with fixing this bug (version #1.0.19). I think it will be available for instalation in 20-30 minutes
@Gordon-R
First of all, I didn’t forget what you wrote about episodes. Sorry if it looks so. I plan that next update will be with many improvements in working with shows\episodes.
At present in the app realized navigation for shows as for music (I wrote earlier). Please take a look on screens below
Technically now you should be able to select any particular episode to play.
Sure…
I have some texts translated but not all.
Could you help me with translation?
Could you, please, give me more details?
Do you use home users?
Plex app asks pin every time too. Maybe I see something in wrong way.
Yes I can :wink:
Give me all the information and I will do the necessary.
Perfect has corrected the ability to use the menu options, now it is what I said that I have an account to choose 2 and before the updates changed entering the account and now if I want to change I have to pair in plextvlink and re-enter, if you can correct it would be more comfortable, thank you for everything already tells me.
Okay. I will send you a file later. Clouser to this weekend, I think
And thank you in advance for help!
@PEDRODOKY
Do I correctly understand that you have 2 plex accounts and would like to link each just once and than just have ability to change an account without re-linking?
I have a plex account with two invitations from two different providers to the same account, until now it was both and I simply switched from one to the other without leaving and having to link it again through plex, now if I want to go from one to the other another one I have to leave and link it again understand me?, thank you.
