XPlay (Android)
Will you get a firestick 4K anytime soon? Do you need help getting one?
It could take about a month to get one.
All I need are 50$ to buy a Fire TV Stick 4K from Amazon and time to make it work.
Mobile version of this would be helpful but not needed imo.
Thanks for listening and applying my recommendation the latest update. Great customer experience
I have 1 more and its more personal so if u decide that its not worthy as improvement then i will be very much fine as is
I like to sort collections by name and right now its only by year.
Like i said if its not worthy, thats cool.
Yes especially if you can implement gapless playback also that would be super sweet
Hello @DironDir
I’m having a problem with the latest version.
When I want to play a file in MPEG-4 Visual format (AVI file converted into MKV), I have the sound but with a black screen: no picture.
I tested on multiple files, same problem.
Can you make a small correction in the next version?
Capture
Thanks ! :wink:
Have you tried the last 1.0.31 version?
And it would be better for me to have an example rather then just the description
I still have the same problem.
I sent you a private message with a file for you to test.
Thank you.
Hi @Th0mAs
It needs some time to analyze.
Unfortunately I could not fixed it fast.
As an experiment.
I’ve added a setting to choose the home screen look.
There are 2 variants:
Big left - is current variant
2 lines - is the new variant
The 1.0.32 version has been released
Hi @DironDir
No problem :wink:
thank you for your work
I am having the same problem as Tomgougoutte, any fix yet?
How do we change the controls. The Nvidia shield controller just doesn’t feel right with the current button mappings. B isn’t back and A isn’t okay it’s Y.
Thanks for information.
Now it should work as it is described in docs:
Anyway I will check it.
The app has no a feature to configure controller’s buttons
Not yet.
At now I could only offer to use the transcode mode for playing such files as temporary decision
The buttons should work as described here:
https://support.plex.tv/articles/206940077-xbox-one-controller-mapping/
Thanks.
I’m going to buy a controller soon to test how it works.
Hi @Th0mAs , @firali92_gmail_com
What I can say about this question now.
To play such a file I need to use xvid decoder. Technically as I see now it is possible but I can’t add this ability to the app because this decoder is under GPL licence.
The license contains some requirements that I can not fulfill because my app is not a “free software”.
So I’ve added a patch in the last version and such videos will be played in transcode mode automatically.
Hi @DironDir,
Thanks for your return.
I tested with version 1.0.33 and the files are read without problem.
I hope that later you will find a solution so that this type of file is read directly because I’m not a big fan of transcoding and my NAS is not very powerful (Synology DS415play).
In any case, I thank you for your responsiveness.
Thank you. :wink:
If you convert your movies from .avi to .mkv maybe is it possible to convert content also with the codec h264, as an example?
It’s not the best solution right now but you will be able to play your files directly
I thought about it but I have a lot of files like that … I do not want to spend weeks re-encoding everything …
In addition, as it is files in SD quality, I will lose a little in quality …
I’m going to leave like this for now and see what that gives.
Thank you :wink:
