Okay, Thank you.
I will take a look at this.
Right now I don’t want to distribute the app in this way. I preffer to work through app stores.
So any answer to this question doesn’t make sense now.
My bad…
The latest firmware for Mi Box 3 contains a bug.
For those of you who are interested, here’s a tip on the command line to manage the passthrough on the mi box:
Enable developer options
adb connect <IP Mi box>: 5555
adb shell settings put global digital_sound 1
adb shell settings put global encoded_surround_output 2
encoded_surround_output 0 = auto (random behavior)
encoded_surround_output 1 = pcm
encoded_surround_output 2 = always
I recommend option 2 (always)
Hey I wanted this app so bad on my firestick 4K that I downloaded an app called aurora store that let me sideload the google play store on to my device to download google play store apps. I was able to get xplay on my firestick but it’s saying you can’t play any media files anymore. I paid for the app . Is it not working because of licensing? I mean I can few all my movies and tv shows on my server just can’t play anything. Only way I can play something is if I select to transcode it.
Sent from my iPhone
Amazon devices don’t use Google API because they use a modified Android version.
I created a new submission for Amazon App Store.
I’m waiting for a response.
@albeno94_gmail_com this is all I can do now.
Hopefully they will accept it. Fingers crossed
lol
Hope so. I wrote more about what Plex is and what my app is and does.
Thank you.
I didn’t notice this one!
Btw, any chance to add the music library to xplay.
I really hate the offical plex player, there is a lot of bugs.
You are welcome.
Yes. As I said earlier I’m going to adapt this for smarts/tablets. But it will take some time.
Still have No news from Amazon.
Looks like they just decided to ignore my submission.
Yea that sucks. I really want to use the app. I might just go buy a nvidia shield tomorrow.
As a variant I could try to make a special “Amazon” version… But you will need to update it manually (for some period at least).
I guess buying a shield is to expensive just for using with the app
As @Th0mAs said a mi box works well too
Could you please try to make a special amazon version? I don’t mind manually updated it.
I would appreciate this as well!
Can you add a new option, a “sleep timer”.
Just to close the app and if possible to close the device after certain time.
Why do you think the app needs such an option?
For example my Nvidia Shield automatically turns off itself after some period of inactivity.
