Server Version#: 1.18.2.2041
Port forwarding is setup properly - I’ve run a packet trace on my router (Mikrotik) where I can see the packets NAT’ing and being sent to my PC. I’ve also setup a 2nd rule to port forward another service and it works without any issues, only plex has issues.
I’ve forwarded 32400 udp and tcp. Using the Plex app on my phone with WiFi, no problems. Over LTE, it just spins for a bit and says can’t connect.
Plex will report it’s not accessible sometimes.
When I hit “retry”, it then shows it as accessible.
Canyouseeme.org has no problems connecting.
Packets are hitting my plex rule and being sent to server
