Synology FAQ - Questions, Answers, and How-To's
FAQ 1: Gaining access to the Plex logs or when PMS isn’t running / won’t start
Your Plex metadata, which is where the logs are stored, is stored out on /volume1 adjacent your content shares. It’s only hidden by default. To make it visible:
DSM 7
  1. Control Panel
  2. Shared Folders
  3. Highlight the PlexMediaServer shared folder
  4. EDIT
  5. “Permissions” tab
  6. Give your Synology username permission to “Read/Write” the share.
  7. Save.
To manually retrieve the logs:
  1. File Station
  2. PlexMediaServer share
  3. Navigate: AppData / Plex Media Server
  4. Right-click Logs
  5. Compress to Logs.zip
  6. Download the ZIP file (click it) to your computer.
  7. Upload it to your thread.
DSM 6
  1. Control Panel
  2. Shared Folders
  3. Highlight the Plex share
  4. EDIT
  7. Save.
  1. File Station
  2. Plex share
  3. Navigate: Library / Application Support / Plex Media Server
  4. Right-click Logs
Go to Index
Nothing is working
Old PMS version in Synology Package Center
What to do when Plex doesn't work
V.1.18.7.2457 Update - Synology DS418play - Fails to work properly
Plex searching for server after restart/reinstall
Trouble setting up Plex on Synology after crash
Remote access does not work after last update
Server Gone; Does Not Come Up When Launhing
Plex Hanging but still using CPU
NAS is currently unavailble
Synology update failure v1.18.9.2571 and reinstall stuck at server is unclaimed
Can't connect to plex server locally nor remotely
Synology plex server stops
Unable to access Plex directly
Cannot connect to Plex any more
Plex unavailable on DSM 6.2.2 - relocated
Plex Unreachable after "Scan Library Files"
Plex shows running but inaccessible
PMS Crashes Daily same time (Restart Required of service)
Synology Dispeared from my servers
Plex on Synology Nas getting errors
Can you set up Plex server entirely remotely on a NAS?
Issue trying to claim server on Synology (was working fine)
Failed to run the Package Services
Plex on Synology suddenly stopped working
Issues with my DS415+
My Plex wont link with my Synology Nas
Plex Folder With all of my Files Has Suddenly Disappeared, Yet all FIles are Accessible Still via the Plex Server?
Failed to run the package service error / DS216+II
Help Please! - I can't seem to figure this one out
I installed a new router and now Plex cannot be found on my NAS Synology system
Unable t create libraries
Can't access first-time setup of a new server on my network
How to force framerate conversion during transcoding if above 30fps?
Plex Stops Working After New Update
Unable re-install Plex on NAS on DSM 6.X
Constantly getting "something went wrong, an unexpected error occurred" or "server settings unavailable"
Plex randomly stops on Synology dsm7
Plex media Server manually stopped in Synology NAS
Plex on Synology DSM 7.2.2 fails to start
Plex Media Server on SYNOLOGY DSM 7.1.1-42962 Update 5 wont run
