"Add to Queue" functions like Play Next
Server Version#: 1.21.1.3766
Player Version#: 1.25.0.1511-47afccd4
When trying to add music to the queue, Plex adds it next in the queue instead of to to the end. This does not happen every time I use the functionality, but it happens often and has been occurring since I first started using Plex for music consistently this past spring.
When this behavior occurred today, I was in the middle of playing an album and then went to add a playlist to the queue. This occurs regardless of which track is playing in the album, unlike here. Likewise, I did notice that this happened when I added a playlist to the queue or an individual track.
I am guessing it is related to the fact that I played a single album from the start, but I will attempt to troubleshoot further and let you know.
EDIT
I am certain that at some point I have been able to use Add to Queue properly in some contexts, but as it stands I have tried starting a playlist by hitting the play button in the top right hand corner, hitting play on the first track, or just hitting the shuffle button–yet when I go to add a song to the queue after the music has started playing it adds it to the #2 slot.
EDIT 2
To completely contradict what I said in the initial post, I am now only able to reproduce the issue if I hit play on a playlist and then try to add another playlist to the queue. If I play an album and add a playlist to the queue, it appears to work, even if I skip the first track or let it finish.
Any word on what can be done about this? I’ve had issues with Plex inserting music into the wrong place in the queue since I first started actively using it (about 9 months now).
