Can no longer rewind media? It just freezes and crashes
Running the newest Plex Server beta and newest shield 2019 beta client. I have attached my Shield logs to this post.
When ever I go to rewind a show or movie it just stays paused and then eventually crashes. It happens at 6:28 in the log file. This seems to be a newer issue. My other clients don’t have the same problem, but they aren’t android tv.
Shield log.zip (33.5 KB)
Having the exact same issue as you on my Nvidia Shield Tube with the newest beta - rewinding or fast forwarding freezes the video.
I was first to report this bug and I already have a post about this that is literally right under yours :wink:
I don’t have any issues fast forwarding and I am using a pro model. You also never provided any logs. I would recommend you upload logs on both your post and mine or they won’t help you.
@sbrentn, those are the Server Logs, what you probably need to post is the Client Log. You can find instructions here:
Shield Tube Logs attached!
shield tube player log.txt (124.3 KB)
