Server Version#: Version 4.140.0
I upgraded from DSM 6.2.2 to DSM 7.1.1 on my DS918+. I had to select my libraries again and noticed my play history was gone. I searched and started following along this comment on Reddit: https://www.reddit.com/r/PleX/comments/15pdx2u/comment/jvxaari/
They mention I need to uninstall Plex but when I try to, it’s all empty and the dropdowns to uninstall or any function don’t work. I have screenshots here. I tried restarting the NAS but it still isn’t working
I just talked with @ChuckPa. There is something wonky with 7.1.1. Update 7. He’s going to talk with Synology.
In the meantime, you have another path.
The DS918+ can be updated to DSM 7.2.2.
Once you’re on DSM 7.2.2, you can then install/uninstall/etc. Plex Media Server like normal (I updated my DS918+ several weeks ago. Plex works fine.).
So, the suggested path forward is:
Update the DS918+ to DSM 7.2.2.
Uninstall Plex Media Server.
Come back to this thread. We need to see where your system is at before proceeding. There are a couple of different ways to proceed. Just need to find where you system is at first.
Note: You will have to manually update the NAS to DSM 7.2.2. Download the file from the Synology support site, then install via Control Panel → Update and Restore → Manual Update.
I am wondering if DSM 7.1.1-42962 Update 7 has similar changes to the packaging that were needed for DSM 7.2.2?
I tried modifying the 72 package to install on DSM 7.1.1-42962 Update 7 but, I did not go deep enough, so it complained about needing a higher version of DSM.
Here’s some screenshots from my DS414 running DSM 7.1.1-42962 Update 7.
In the main Package Center window, Run and Open work.
In the Package Center windows for Plex Media Server, the detailed information is incorrect/blank. The pulldown menu shows “Install,” even though Plex Media Server is installed and running.
And, as in @trumpy81’s screenshot, anything selected from the pulldown menu does not work.
Thanks. I was going to do the update but then I saw the release notes for 7.2.2 and I won’t be able to view HEIC/HEIF photos or HEVC videos anymore without converting them. I use the Synology Photos app to backup my photos so I’m hesitant to upgrade. I’ll have to see what workaround I can do to make the photos work.
I helped @ChuckPa get a DSM 7.1.1 VM up and running and when he has time to do some snooping, he may be able to devise a plan of attack to overcome this issue, at least until Synology release a fix for the issue.
pardon my ignorance, but is there a way I can run those commands within Synology without having to open up SSH service? I tried looking for the terminal program but couldn’t locate it.
Thanks for your guidance so far. I was able to SSH into my NAS and shut down Plex. A bit of a moot point since I need to upgrade the DSM version to get Plex corrected, right? What commands should I run to uninstall Plex from my NAS? After I do so, should I attempt reinstall of Plex or will I run into the same issue of my metadata going missing?
