Server Version#: 1.20.2.3370
Player Version#: 7.6.1
Ever since the most recent update of the iOS Plex app I’ve been unable to watch anything by casting to my Chromecast Ultra. The media will start playing, but stops and the chromecast returns to its idle screen abruptly after approximately 1 minute of playback. If however I grab an Android device and set up the casting from that, it will play without issues, so I know the problem is specific to the iOS player.
I found some older articles suggesting that the “Terminate Sessions Paused for Longer Than” option can cause this, and tried blanking it as they suggested however it seems the current version of Plex Media Server will default that back to 0 if it’s left blank.
I have this same issue. If I swipe to close the app it’s fine, but if I leave it running it will stop playback I whatever device I’m casting to (I have several different types). Definitely a bug in iOS.
Bumping.
I’ve tried setting the “Terminate Sessions Paused for Longer Than” to various different things. 0, 30, 300, etc and it doesn’t seem to make a difference.
I also have 3 different types of Chromecasts. 1st gen, 2nd gen, and the new “Chromecast with Google TV” all which act that same.
I just tried xCALCULON’s suggestion of once casting starts closing the Plex app on my iPhone and that appears to prevent the issue from happening.
Are all of you on version 7.6.1? I am trying to reproduce with the current 7.8.1 and it seems to play fine. I’m about 30 min into a movie right now. App remains open on my iPad
Definitely not IOS. I’ve been complaining about this issue for over a month, and nothing. I can stream from my nas to the firestick. The Chromecast cast will work for one show, and then it stops on another.
I’m on iOS 14. I’ve rolled back my Plex back several updates, and it seems to work for a bit and then back to 1 min shut down
I didn’t mean it was iOS fault but it might be a combination of things. I’ve now tested on multiple devices and I can’t repro on any of them. if you can provide the app logs after it happens it would be appreciated.
Thank you for checking. Just to add that I have tested with two iPhones, two different TVs, a Chromecast and a Chromecast Ultra and the issue is the same with all devices.
The only way to avoid the issue is to close the app once you’ve started casting.
