Confused about computers
Hello,
I have recently lost access to my entire library of TV shows and movies etc. It was all working fine last week. Looking on the web player of Plex (i.e. Plex.tv) and in the (empty) Home Screen and clicking on MORE, I see that there are two servers, my Synology NAS and my desktop Mac mini M2 desktop computer.
I usually serve films etc. from the NAS; should I be using my Mac M2? Is this why the system can’t seem to find my files (which are definitely there on the NAS)?
I wonder if someone could point me in the right direction, please. Thanks.
It sounds like all your pinned libraries got unpinned. If the libraries are all listed under More you just need to go through and re-pin the libraries, and arrange the order to suit you.
You are free to host media on whichever Plex server you want (NAS or Mac Mini), but most people would have only one Plex server running (on the more capable device, the one that is more power efficient, or the one that operates 24/7 if the other doesn’t). It depends on what you value most. The storage for the media can be on whichever device you want but needs to operate at least at all times the Plex server is up.
Thank you, makes perfect sense. However I only have ‘Watchlist’ that is pinnacle. There is notning else there.
If Plex Media Server is unintentionally running on the Mac, stop it, then uninstall Plex Media Server.
Then go to Authorized Devices, sort for Servers, and delete the entry for Plex Media Server on the Mac. Do not delete the entry for Plex on the Synology. If there are any old/outdated servers listed, then delete them as well.
Synology Control Panel → Info Center
  • NAS model?
  • DSM version?
Synology Package Center → Plex Media Server (click on Plex icon) → Installed Version
  • Plex Media Server version?
If Plex Media Server is not running, start it.
Login to Plex using the IP address of the NAS. For example, if the IP address is 10.1.2.3, use http://10.1.2.3:32400/web (or https if needed).
Go to Settings (wrench icon) → server_name → Libraries (not Library).
Are your libraries listed?
Thank you. Here is my data:
NAS model: DS218play
DSM version: DSM 7.4.1-90080
Installed version: 1.43.4.10903-720010903
I didn’t quite follow your instruction about logging into Plex using the IP address of the NAS. Logging in where exactly?
http://addrers.of.my.nas:5000/web as a web destination in my browser gives me the error:
“SYNOLOGY: Sorry, the page you are looking for is not found.” Using https gives me a “Secure Connection Failed” error. I may be barking up the wrong tree, I realise.
p.s. slightly oddly, I can play music from the NAS in Plexamp.
Thanks for the info.
Logging directly in to your Plex Media Server, instead of using app.plex.tv.
For example, the IP address of my DS918+ is 192.168.1.50. I can login to the Plex Media Server via http://192.168.1.50:32400/web.
Try this:
  1. Reboot the NAS. Wait however long it takes for the NAS to reboot and Plex to start.
  2. Point a browser at http://address.of.nas:32400/identity.
    You should see one line of XML with claimed="0" (unclaimed) or claimed="1" (claimed).
    If you see a secure connection warning go ahead and proceed. You’re connecting to your own server. This is just a test that Plex is running and responding.
  3. Now try to login to Plex using http://address.of.nas:32400/web.
You should be able to login, reach the server settings, claim the server if necessary, see if libraries are still there (Settings → Libraries), etc.
Great, thanks for your clear instructions, I did step 1 & 2 (the server in the XML was 1, claimed)
I could indeed log into my own account at http://address.of.nas:32400/web . The server settings page (Version 1.43.5.11029) confirmed that I had claimed the server, but the libraries aren’t anyway to be seen. Although the system page refers to the Mac mini, rather than the NAS, where all the files live. i.e. Settings>Mac mini>Libraries
Should I be keeping all the said files on the Mac mini, anyway? Plex seems to be using Plex Media Server on the Mac again (see your help in posting 3, above.)
Hi, I followed all the instructions, but I am once again back to the same empty Plex home page (see image)
Thanks for the info and the screenshot.
  1. Go to Settings (Wrench icon)
  2. You should see the server name, Mac mini, listed on the left, with Status, Settings, etc. sections listed below.
  3. Go to Manage → Libraries.
  4. Do you see your libraries listed?
No, nothing (‘0 libraries’) under Mac mini → Manage → Libraries
Also of note you appear to have two Plex accounts. I think you are signed into the correct account that has your Plex Pass and servers, but don’t use the “Sign in with Google” option as that will sign you into your other account that does not have a Plex Pass nor any servers. ( I can delete this extra account if you like)
Yes please, delete away. Sound like it could be the root of my issue…
Done. Not sure if will solve issue though as your main account’s servers still show zero libraries.
Well the NAS shows 5 libraries but that server shows as not being seen for 9 days.
The Mac Mini shows zero servers but was last seen a few hours ago.
Will it make any difference if I do a restore from my USB NAS backup drive? It’s all a bit strange, as I am looking at a file listings on the said NAS at the moment!
9 days is about the time that I lost all access to my stuff.
Many thanks.
Given the possible mix-up on sign-ins and that the Plex server on the NAS has not been seen in 10 days, let’s cover some basics first.
  1. If Plex Media Server is installed on your Mac:
    A Plex icon should be visible in the menubar.
    Click on the Plex icon and ensure that “run at startup” is not enabled.
    Stop Plex Media Server on the Mac.
  2. Configure the NAS to use a public DNS server.
    Synology Control Panel → Network → General tab
    Check the box to Manually configure DNS server.
    Enter a preferred and alternative DNS server.
    Use a public DNS server such as 1.1.1.1 (Cloudflare), 8.8.8.8 (Google), or 9.9.9.9 (Quad9)
Screenshot: Synology DNS Settings
  1. Sync the NAS with a public NTP server
    Synology Control Panel → Regional Options → Time tab
    Choose Synchronize with NTP server
    Pick a server from the drop down list
    Update Now
    You should see Status = Normal
Screenshot: Synology NTP Settings
  1. Verify you are using the correct Plex account
    Go to Account Settings: https://app.plex.tv/desktop/#!/settings/account
    Verify the username is correct.
    Verify the e-mail address is correct.
    If incorrect, sign out and login with the correct account.
  2. Verify Plex Media Server on the NAS is claimed by the correct account
    Follow FAQ 31: Reset / Reclaim PMS on DSM 7 (Not Authorized - Locked Out).
    The process will have you uninstall, then re-install Plex Media Server using a Plex Claim Token.
    IMPORTANT: Ensure the message at the end shows your server is claimed by the correct account. If you see anything different, post a screenshot of the message.
If all steps are successful, then Plex Media Server will be installed & running on the NAS and also successfully claimed by your account.
You should be able to login via https://nas_ip_address:32400/web, reach server settings, see any libraries on that server, etc.
When you say ’stop’, is that the same as just selecting ‘quit’ from the menu? Anyway, Plex appears to have stopped (the arrow has gone from my menu bar.
I don’t appear to have “run at startup” as a check box selection, it’s just a drop down selection when PMS is running (see screenshot).
That’s where things don’t work; I am getting an “unable to sync” error when clicking on “Update now”, even though my computer is hardwired to the router; it fails even when I switch wireless back on. Heading to the Synology help page at https://kb.synology.com/en-uk/DSM/tutorial/Troubleshooting_issues_syncing_with_NTP_server and just clicking on “Update now” as they suggest, I get a different message, “error while trying to sync”, so I am unable to progress further…
Thanks for the screenshots.
Yes, Stop = Quit. Also, “Run at Startup” = “Open at Login.” I don’t have a Mac, and wasn’t sure of exact wording.,
That is a problem. Notice the text in red in the screenshot. It indicates a problem with the Synology network configuration or with your network.
How is the Synology connected to the network? Directly to the router via an Ethernet cable?
Try power cycling the router. Don’t just reboot/restart it. Power it off (pull the power plug if needed). Wait one minute. Power it back on. Just need to do this once. It will either help or it won’t.
When the router is back online, try to sync the Synology with a NTP server again. You can also try a different NTP server. Click the down arrow to the right of time.google.com. You should see a list of servers.
Why this matters…
To operate correctly, Plex Media Server must be able to communicate with servers at plex.tv. Synchronizing the NAS with a public NTP server is a basic test of network connectivity. If the NAS cannot communicate with a public NTP server then it likely will have trouble communicating with servers at plex.tv.
I’m on it, and will report back. Thanks.
Well, I tried multiple ways (each of the 3 servers with both wired and wireless connection to my router) to sync the NAS, but all failed. (“TIME - Error occurred while DiskStation was synchronizing with Server address” or other message). I am going to raise this with Synology as they suggest, but do you have any further advice?
