@TeknoJunky
Indeed that helped, thanks! Weird though.
its possible that your show was originally matched to a different tvdbid, then unmatch/match pulled a new/different id.
or just a caching issue that cleared itself.
there are still weird metadata issues for various shows including this one, as you can see @ Match Failures
The now possibly defunct: 378579 for Possible Worlds that draws no metadata:
https://thetvdb.com/series/cosmos-possible-worlds
Fix Match now goes to Cosmos 2014 Season 2 - a guess since a natural match is only achieved by the Season 02 method and no metadata is coming out of TVDB any other way.
A test would be to Fix Match to 378579 and see what happens.
I suspect youâd get a bunch of blank posters.
View the âwall-0-textâ in an episode XML for this passage:
<Video ratingKey="79916" key="/library/metadata/79916" parentRatingKey="77695" grandparentRatingKey="77669" guid="com.plexapp.agents.thetvdb://260586/2/5?lang=en" parentGuid="com.plexapp.agents.thetvdb://260586/2?lang=en" grandparentGuid="com.plexapp.agents.thetvdb://260586?lang=en" type="episode" title="The Cosmic Connectome" titleSort="Cosmic Connectome" grandparentKey="/library/metadata/77669" parentKey="/library/metadata/77695" librarySectionTitle="TV - Shows" librarySectionID="5"
for the ID# being used at TVDB.
Mine is Cosmos (2014) - ID# 260586
What do Cosmos Possible Worlds Fix Match people see?
Fix match is not a magical fixing thing, itâs just a search you can edit and browse through matching alternatives. Search for Cosmos: Possible Worlds. The â:â is important.
ID of the show that fixed the problem for me is: 378579. The exact show I posted in my first reply to you, where you can clearly see metadata and posters. The show it was matched to in the beginning. As i said, it was a plex issue, which is fixed now. Thanks again @TeknoJunky
I was specifically looking for the ID# in the XML for an episode after Fix Match.
It doesnât matter - Name it right or Fix Match - pretty much just like always.
@JuiceWSA
I gave you the ID # in the XML.
@Coxeroni
We know this. Did you read the thread?
The ID# you gave doesnât fit anything.
Was just curious what it was now that you used Fix Match so you can get posters.
Itâs ok - This horse is dead - beating it further will have no effect one way or the other.
It does not?
As I said, what fixed it for me was manually unmatching and then manually matching, as TeknoJunky instructed.
They moved it to Season 2 of Cosmos (2014), so rename your episodes to S02Exx
and match to Cosmos (2014)
So weird that you just updated this when I was trying to suss it out. Anyway, THANK YOU. Itâs now sorted
Great, i hope its final.
haha⊠too many contributors with nothing else to do.
thereâs been a number of shows that got a heavy makeover â itâs odd if you notice ânew stuffâ after a metadata refresh (simply because someone changed the order of some specials)
I only figured this out, when adding extra episodes, they did not get any metadata of course. so Then the search of TVDB helped.
We, in the trade, call that:
âThe TVDB Two-Week-Two-Stepâ
Just when you thought it was safe to go back in the waterâŠ
