Server Version#:1.40.2.8395
Player Version#:Roku Ultra (latest app)
Where is the default backup location? Everything I find indicates the database location (/PlexMediaServer/AppData/Plex Media Server/Plug-in Support/Databases), but that’s the ORIGINAL location. You cannot back to the original location, at least not using the original names, so the backup should be somewhere else. The location itself should be “standardized” regardless of OS platform, at least 3 or 4 levels down, so even if your server is on Windows or Mac, that info might be helpful.
I need to get that info as my settings somehow has this as blank (undefined) - I know it was their prior to reinstalling Plex as I saw the box was too small to show the entire path. But, I’ve been scrambling round trying to restore the server (from accidentally deleting it myself) and probably fat-fingered it
Anyway, I need the actual location to not only correct the setting, but to locate the backup so I can restore it. Reinstalling Plex didn’t remove previous configuration as it should have.
Database Backups are indeed located in the database folder. The file names have a timestamp suffix to distinguish them from the original (active) database file.
