Hi all
not sure if this is where I should be asking this - if it should be elsewhere let me know.
I have series 1 - 7 of the more recent run of Doctor Who (the ones starting with Christopher Ecclestone)
When I put them into my TV series folder they get picked up as the original series (the ones starting with William Hartnell). I get why it is doing this but can anybody tell me what to do to get the metadata for the series that I actually have?
I realise I may have to rename the files - but I dont know what to.
TIA
John
- Look up your show on TheTVDB
- Take the title as it is used on TheTVDB. If there is something in parentheses, take that too. If the title contains invalid characters (depends on your file system), like
§ : % *, simply leave them out.
- Check the naming and the folder structure of your show. Name the top folder of the show exactly after the title on TheTVDB. No abbreviations. No additional subfolders. No aliases.
- Name the episode files according to the above linked naming guide. Use the same title as for the top folder.
Show's Title - s01e01 - additional info.ext (’- additional info’ can be left out)
- After you corrected the naming and folder structure, perform the Plex Dance with all files for this show.
- will show you that you have to use
Doctor Who (2005) as the show’s title
Filebot allows you to quickly change the naming of a whole tv show.
Thanks for the quick answer - I will investigate in the morning.
Cheers
John
