DSM 7 - Plex Media Server (1.24.5.5173-7000) breaks "Live TV & DVR"
I restarted PMS again and recreated the issue (the more the merrier) in case it helps.Plex Media Server Logs_2021-11-12_11-03-13.zip (2.9 MB)
@senoj_nai
Do you have your locale (region) initialized on the Syno?
Your logs all look like this:
Supplemental:
Nov 12, 2021 10:43:49.692 [0x7f698771eb38] ERROR - [Transcoder] [NULL @ 0x7f6013b64b40] SPS unavailable in decode_picture_timing
Nov 12, 2021 10:43:49.693 [0x7f69876c7b38] ERROR - [Transcoder] [NULL @ 0x7f6013b64b40] non-existing PPS 0 referenced
Nov 12, 2021 10:43:49.694 [0x7f6984846b38] ERROR - [Transcoder] [h264 @ 0x7f6013b64b40] SPS unavailable in decode_picture_timing
Nov 12, 2021 10:43:49.695 [0x7f69849f5b38] ERROR - [Transcoder] [h264 @ 0x7f6013b64b40] non-existing PPS 0 referenced
Nov 12, 2021 10:43:49.696 [0x7f69849a7b38] ERROR - [Transcoder] [h264 @ 0x7f6013b64b40] decode_slice_header error
Nov 12, 2021 10:43:49.696 [0x7f69846a2b38] ERROR - [Transcoder] [h264 @ 0x7f6013b64b40] no frame!
Nov 12, 2021 10:43:49.697 [0x7f6984823b38] ERROR - [Transcoder] [h264 @ 0x7f6013b64b40] SPS unavailable in decode_picture_timing
Nov 12, 2021 10:43:49.698 [0x7f698467fb38] ERROR - [Transcoder] [h264 @ 0x7f6013b64b40] non-existing PPS 0 referenced
Nov 12, 2021 10:43:49.698 [0x7f69848a9b38] ERROR - [Transcoder] [h264 @ 0x7f6013b64b40] SPS unavailable in decode_picture_timing
Nov 12, 2021 10:43:49.699 [0x7f6985529b38] ERROR - [Transcoder] [h264 @ 0x7f6013b64b40] non-existing PPS 0 referenced
Nov 12, 2021 10:43:49.699 [0x7f69847e0b38] ERROR - [Transcoder] [h264 @ 0x7f6013b64b40] decode_slice_header error
Nov 12, 2021 10:43:49.699 [0x7f6985422b38] ERROR - [Transcoder] [h264 @ 0x7f6013b64b40] no frame!
Nov 12, 2021 10:43:49.700 [0x7f6984a18b38] ERROR - [Transcoder] [h264 @ 0x7f6013b64b40] SPS unavailable in decode_picture_timing
Nov 12, 2021 10:43:49.701 [0x7f698771eb38] ERROR - [Transcoder] [h264 @ 0x7f6013b64b40] non-existing PPS 0 referenced
Nov 12, 2021 10:43:49.701 [0x7f69876c7b38] ERROR - [Transcoder] [h264 @ 0x7f6013b64b40] SPS unavailable in decode_picture_timing
Please add the following preference to your Preferences.xml:
  1. Install Synology “Text Editor” app
  2. Stop Plex
  3. Open FileStation
  4. Navigate PlexMediaServer/AppData/Plex Media Server
  5. Right-click Preferences.xml → Open with Text Editor
  6. On the last line, before the closing />,
  7. Add: VaapiDriver="i965"
  8. It will look like: SomePref="Value" VaapiDriver="i965" />
  9. Save the file
  10. Start Plex
  11. Retest
Please let me know if this helps or not.
So the end of the last line is now: logDebug=“0” ScheduledLibraryUpdateInterval=“86400” MergedRecentlyAdded=“1” VaapiDriver=“i965”/>
The video is very stuttery and there is no sync with sound.
What the heck?! I took the setting out and restarted PLex thinking that was all the testing I needed to do but then thought it might help if I continue running with these settings, even though the playback was unwatchable, just in case the logs show something different.
When I re-applied the settings: logDebug=“0” ScheduledLibraryUpdateInterval=“86400” MergedRecentlyAdded=“1” VaapiDriver=“i965”/> and restarted PMS again, the TV is watchable - in sync and everything.
It just aborted again though so the logs are attached.
P.S. All the settings I can see are set to English. Puttying into the NAS shows the locale as:
[Plex Media Server Logs_2021-11-12_22-55-52.zip|attachment]
(upload://A8BNDMZGnMyDjvKnquCY5jTkqax.zip) (1.9 MB)
daddy@myth:~$ locale
LANG=en_US.utf8
LC_CTYPE=“en_US.utf8”
LC_NUMERIC=“en_US.utf8”
LC_TIME=“en_US.utf8”
LC_COLLATE=“en_US.utf8”
LC_MONETARY=“en_US.utf8”
LC_MESSAGES=“en_US.utf8”
LC_PAPER=“en_US.utf8”
LC_NAME=“en_US.utf8”
LC_ADDRESS=“en_US.utf8”
LC_TELEPHONE=“en_US.utf8”
LC_MEASUREMENT=“en_US.utf8”
LC_IDENTIFICATION=“en_US.utf8”
LC_ALL=en_US.utf8
@senoj_nai
please upload again / fix that link.
You hit reply before it completed (it won’t say attachment when completed)
After you try this… REMOVE the setting.
Plex Media Server Logs_2021-11-12_22-55-52.zip (1.9 MB)
The reply button is greyed out until the upload has completed so I don’t get how the upload is not working. I waiting a further 10 secs after it told me the update was complete just to make sure.
Yes, I will remote that setting now.
I see 1.25.0.5220-de6e61df7 is now available.
Would you prefer to continue debugging this or shall I upgrade?
Go for it. That should be the new transcoder update.
PlexMediaServer-1.25.0.5220-de6e61df7-x86_64_DSM7.spk installed.
I’m afraid the issue is still with us. Here are the logs:
Plex Media Server Logs_2021-11-13_10-27-29.zip (1.1 MB)
@senoj_nai
Would you please turn DEBUG logging on again? I can’t see anything.
  • Settings - Server - General - Show Advanced
  • Check the box
  • SAVE
  • Restart PMS and retest
Strange - Debug was set to Verbose. This option is not under Settings - Server - General - Show Advanced but instead under Settings - Debug.
I have turned debug off - save changes - then back to Verbose - save changes and then restarted PMS.
Plex Media Server Logs_2021-11-13_17-07-18.zip (1.1 MB)
Here’s another fail with Debug set to Enabled rather than Verbose in case it makes any difference
Plex Media Server Logs_2021-11-13_17-14-13.zip (1.1 MB)
Is there any more information I can provide to help fix this issue?
I’m sorry – I was not notified.
I’m having a heck of a time with this because I don’t have DVR capability here.
Looking through your logs again, I see the sonos devices but I don’t see the tuner.
Nov 12, 2021 22:54:22.995 [0x7fcc84a22b38] DEBUG - Completed: [127.0.0.1:56827] 404 GET /:/plugins/com.plexapp.agents.thetvdb (2 live) GZIP 0ms 350 bytes
Nov 12, 2021 22:54:23.824 [0x7fcc843dab38] DEBUG - DVR:Device: Discovering and refreshing all devices.
Nov 12, 2021 22:54:23.824 [0x7fcc843dab38] DEBUG - Grabber: HDHomerun discovered 0 compatible devices.
Nov 12, 2021 22:54:23.824 [0x7fcc843dab38] DEBUG - HTTP requesting POST http://127.0.0.1:32600/devices/discover
Nov 12, 2021 22:54:24.127 [0x7fcc84451b38] DEBUG - NetworkServiceBrowser: SERVER arrived: 127.0.0.1 (Hera)
If you want, we can try an older version of PMS to see if identifying the tuner is what’s broken ?
If you do this:
  1. UNInstall w/ Keep (default) action
  2. Install this older version
  3. Give it another 1-2 minutes to get stabilized at the lower level
  4. Repeat your testing.
It refuses to roll back to the older version.
Would you like me to screen-share?
Ah - option 1 should read Uninstall… gotit.
As suspected, this older release is stable.
Would you like to see any debug logs anyway?
:man_facepalming: Fixed :slight_smile:
