DSM 7 - Plex Media Server (1.24.5.5173-7000) breaks "Live TV & DVR"
do you have both sets of logs ?
If so, let’s see what the differences are .
Plex Media Server Logs_2021-11-18_19-30-28.zip (2.1 MB)
You forgot DEBUG logging :smiley:
Enable it, save , restart
It was enabled!
I’ll turn it off and on again… stand by :grinning_face_with_smiling_eyes:
Going to need a database optimization too when you get to it.
Nov 18, 2021 19:29:55.070 [0x7f957b83db38] ERROR - XML: ^\00
Nov 18, 2021 19:29:55.070 [0x7f957b83db38] ERROR - Error parsing content.
Nov 18, 2021 19:29:55.070 [0x7f957b83db38] ERROR - Error parsing XML: Error parsing file.
Nov 18, 2021 19:29:55.070 [0x7f957b83db38] ERROR - SSDP: Error parsing device schema for http://192.168.1.107:9080
Nov 18, 2021 19:29:59.020 [0x7f957c201b38] WARN - SLOW QUERY: It took 3160.000000 ms to retrieve 9 items.
Thanks for the tip - optimizing now…
Plex Media Server Logs_2021-11-18_19-35-13.zip (2.1 MB)
Are these logs any better?
No.
Are you restarting?
Nov 18, 2021 19:20:38.233 [0x7f957d4d3b38] INFO - Plex Media Server v1.24.2.4973-2b1b51db9 - Synology DS916+ x86_64 - build: linux-x86_64 synology-dsm7 - GMT 00:00
Nov 18, 2021 19:20:38.233 [0x7f957d4d3b38] INFO - Linux version: DSM 7.0.1.42218-0, language: en-US
Nov 18, 2021 19:20:38.233 [0x7f957d4d3b38] INFO - Processor       Intel(R) Pentium(R) CPU  N3710  @ 1.60GHz
Nov 18, 2021 19:20:38.233 [0x7f957d4d3b38] INFO - Compiler is - Clang 11.0.1 (https://plex.tv e0c29d5827bc4eaaa2ceb882cbeed224b0960173)
Nov 18, 2021 19:20:38.233 [0x7f957d4d3b38] INFO - /volume1/@appstore/PlexMediaServer/Plex Media Server
Nov 18, 2021 19:20:50.125 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:50.130 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:50.134 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:50.139 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:50.143 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:50.148 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:50.153 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:50.157 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:50.162 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:50.167 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:50.171 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:50.176 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:50.181 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:50.185 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:50.192 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:50.196 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:50.201 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:50.206 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:50.210 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:59.930 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:59.934 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:59.939 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:59.944 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:59.949 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:59.953 [0x7f9580b6f258] INFO - SQLITE3:0x80000001, 17, statement aborts at 57: [select * from metadata_items limit 1] database schema has changed
Nov 18, 2021 19:20:59.958 [0x7f9580b6f258] INFO - SQLITE
No - when it started after install it was enabled. I will restart now.
Plex Media Server Logs_2021-11-18_19-39-59.zip (2.0 MB)
Debug set to Enabled, PMS restarted.
I’ll do it again with Debuf set to Advanced (incl. PMS restart)
Sorry - not Advanced, Verbose.
Settings - Server - General - SHOW ADVANCED
  1. DEBUG logging enabled
  2. VERBOSE logging disabled (unchecked)
  3. Then restart
Plex Media Server Logs_2021-11-18_19-43-36.zip (1.8 MB)
Debug isn’t there for me - it’s under Debug. Screenshot to follow…
You don’t have this?
Notice how “General” is highlighted.
Ah, yes I do. I went to the Plex Web Debug option. sigh…
One moment
Like an idiot, I never used that option, I was fixated by the Debug option under the Web part.
As a result, you have never received a debug from the latest version.
Would you like me to upgrade to the buggy version and send you a REAL debug log?Plex Media Server Logs_2021-11-18_19-52-20.zip (1.3 MB)
Yes,
Now that PMS (this version) has found and reported
Nov 18, 2021 19:49:44.109 [0x7f1550923b38] DEBUG - Grabber: HDHomerun discovered 0 compatible devices.
Nov 18, 2021 19:49:44.109 [0x7f1550923b38] DEBUG - DVR:Device: Testing grabber HDHomerun device device://tv.plex.grabbers.hdhomerun/2021-06-RV9O-F84UJ4:4 at http://192.168.1.3:34400
Nov 18, 2021 19:49:44.109 [0x7f1550923b38] DEBUG - DVR:Device: Device device://tv.plex.grabbers.hdhomerun/2021-06-RV9O-F84UJ4:4 was already known, refreshing database info
Now upgrade and let’s see if it finds it again.
I am curious why it’s marked as dead:
Nov 18, 2021 19:49:44.109 [0x7f1550923b38] DEBUG - HTTP requesting GET http://192.168.1.3:34400/discover.json
Nov 18, 2021 19:49:44.110 [0x7f1550923b38] ERROR - Error issuing curl_easy_perform(handle): 7
Nov 18, 2021 19:49:44.110 [0x7f1550923b38] WARN - HTTP error requesting GET http://192.168.1.3:34400/discover.json (7, Couldn't connect to server) (Failed to connect to 192.168.1.3 port 34400: Connection refused)
Nov 18, 2021 19:49:44.111 [0x7f1550923b38] ERROR - DVR:Device: Error refreshing existing device device://tv.plex.grabbers.hdhomerun/2021-06-RV9O-F84UJ4:4, marking as dead.
Nov 18, 2021 19:49:44.113 [0x7f1550923b38] DEBUG - DVR:Device: Device device://tv.plex.grabbers.hdhomerun/2021-06-RV9O-F84UJ4:4 died
Is this the right device ?
It’s the only device I have.
If you remember, there used to be a TVButler USB device but DSM7 stopped supporting them. The config is still knocking around inside plex somewhere though.
I have upgraded to 1.25.0.5246 again and the TV has cut out once more.
Logs attached: Plex Media Server Logs_2021-11-18_20-03-44.zip (928.8 KB)
Thanks for this.
For now, Downgrade again and run there. It’s important to me that you have a functioning system
