DVR no longer operational, cannot setup new DVR
That is what appears to be happening as can be seen in the logs
You probably have a scheduled task starting Plex Media Server.exe as well as it is starting by default on launch
You had 2 instances of Plex Media Server.exe processes running in parallel at 16:51:34
Normal auto launch of PMS (Plex Media Server.3.log)
May 19, 2021 16:51:34.126 [10624] INFO - Plex Media Server v1.22.3.4523-d0ce30438 - Microsoft PC x64 - build: windows-x86 windows - GMT -05:00
Scheduled task launch of PMS (Plex Media Server.4.log)
May 19, 2021 16:51:27.874 [9476] INFO - Plex Media Server v1.22.3.4523-d0ce30438 - Microsoft PC x64 - build: windows-x86 windows - GMT -05:00
and again from 17:19:57 - two parallel instances running
Normal auto launch of PMS (Plex Media Server.log)
May 19, 2021 17:19:57.008 [8580] INFO - Plex Media Server v1.23.1.4528-c0513eb4c - Microsoft PC x64 - build: windows-x86 windows - GMT -05:00
Scheduled task launch of PMS (Plex Media Server.1.log)
May 19, 2021 17:19:49.936 [8120] INFO - Plex Media Server v1.23.1.4528-c0513eb4c - Microsoft PC x64 - build: windows-x86 windows - GMT -05:00
Suggest you remove the scheduled task and just have auto launch
Or alternatively look into using this add-on product: PMS as a service - General / Tips, Tricks & How-Tos - Plex Forum
I would echo Tiebierius about the restart of programs in Windows 10, which will load a second instance in addition to Plex’s autoload. See https://tinyurl.com/kejdzpxh. Of course, the real answer is to have Plex check and not load another instance of itself.
I finally just gave up. this is still unstable almost a year in. I so loved the idea. Streaming TV from anywhere. There are no answers. There are no solutions.
Don’t think there were any logs provided for your issues. Last I can see is that you had 2 instances of Plex Media Server.exe running - here DVR no longer operational, cannot setup new DVR - #35 by buddykins which can arise if you have “Start Plex Media Server at Login” selected and also run it as a scheduled task or service,
