DVR Setup Stuck
Confirmed! Deleting the DVR on startup and then re-adding it actually worked.
Thanks for the solution to this mess so I could get my DVR and Live TV working in time for Football.
This web page gives info on xmltv epg sources
https://support.plex.tv/articles/using-an-xmltv-guide/
I have seen forum posts on use of zap2xml for europe
Thanks for the info, I’ve checked this page before, but it my country isn’t listed. And it’s paid service anyway, I don’t see a reason why to pay twice for one service.
I’m having the same DVR issue in 1.16.4.1469. I can add a DVR device but I have to use an external epg.
Windows server 2019
Processor 3.30GHz E3-1225 v5
Memory 8GB DDR3
I hope this is the additional info you require for debuging this issue.
Cheers!
Is your country showing as supported for the EPG?
See list here https://support.plex.tv/articles/226463767-frequently-asked-questions-dvr-live-tv/
If it is supported could you provide server logs with debug logging enabled covering time when DVR setup hangs
I only recently switched from MythTV to using DVR/LiveTV (although plex-pass subscriber for some time.)
Can I force to use my paid schedules direct, instead of the native plex one (Based in west coast zipcode 94505).
I have multiple PMS instances and would like to compare the EPG metadata and then decide.
For the EPG, you have the option to use xmltv file - see https://support.plex.tv/articles/using-an-xmltv-guide/
But I suppose you have to do the retrieval of the xml file yourself?
The interface allows you to enter the path to your xmltv file. So yes.
How frequent does plex look at the xmltv file for any changes? or does it look for when when its been ONOTFYied?
I believe it is the same periodic incremental refresh which is run 4 hours after the last one. Incremental refresh looks for changes in following 24-48 period at the end of the 13-14 day period incrementing the guide data held by a day.
Using Plex Version 1.16.5.1488.
Mac mini late 2014
Processor 2.6GHz core i5
RAM 8GB
OS Mojave 10,14,6
XML TV guide - ICE TV
Fresh setup of HD Homerun, just spins after entering xml url.
Please could you help?
Would need to look at server logs when it gets stuck
See this post for getting diagnostics DVR Setup Stuck - #78 by sa2000
if you go to http://freepg.tv/ sign up for EPG in your area then choose have an XMLTTV then paste the link they sent you it will work…im in Australia as well.
