Error code: s1003 (Network) (HW transcode failing - SOLVED)
Server Version#: 1.24.3.5033
Player Version#: 4.66.1
I just upgraded my ubuntu server, and now I’m getting a s1003 error when trying to play a lot of the videos (but some play fine, and it seems to be consistent which one do and doesn’t play).
after this happens (closing the dialog box above and not doing anything else) there are several processes on the server running at 100% and they don’t appear to end on their own, requiring a restart of the plexmediaserver service.
UPNP is turned off at the router.
Plex runs directly on the os, not virtual/container.
The files are definitely readable and available (accessed through a nfs share from the NAS).
on server startup this is in the system.log:
2021-09-28 09:51:50,011 (7fdc21df2b38) :  CRITICAL (storage:60) - Exception reading file /usr/lib/plexmediaserver/Resources/Plug-ins-757abe6b4/WebClient.bundle/Contents/Info.plist (most recent call last):
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-757abe6b4/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/storage.py", line 55, in load
    f = open(filename, mode)
IOError: [Errno 2] No such file or directory: '/usr/lib/plexmediaserver/Resources/Plug-ins-757abe6b4/WebClient.bundle/Contents/Info.plist'
2021-09-28 09:51:50,012 (7fdc21df2b38) :  CRITICAL (bundleservice:141) - Exception adding bundle: WebClient.bundle (most recent call last):
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-757abe6b4/System.bundle/Contents/Code/bundleservice.py", line 131, in update_bundles
    Log('Found duplicate identifier at %s for bundled plugin (%s), ignoring duplicate plugin.' % (path, bundle.identifier))
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-757abe6b4/System.bundle/Contents/Code/bundleservice.py", line 18, in __init__
    self.load_plist()
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-757abe6b4/System.bundle/Contents/Code/bundleservice.py", line 22, in load_plist
    plist = Plist.ObjectFromString(Core.storage.load(Core.storage.join_path(self.path, "Contents", "Info.plist")))
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-757abe6b4/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/parsekit.py", line 32, in ObjectFromString
    check_size(string, max_size)
  File "/usr/lib/plexmediaserver/Resources/Plug-ins-757abe6b4/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/parsekit.py", line 22, in check_size
    if len(data) > max_size:
TypeError: object of type 'NoneType' has no len()
For a video that does work the logs say this about the transcoding:
Sep 28, 2021 09:52:33.478 [0x7fb2ca5a7b38] DEBUG - Request: [192.168.1.110:62906 (Subnet)] GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flibrary%2Fmetadata%2F12496&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=9w1klh2c038bqjll7104rfj9&subtitles=burn&Accept-Language=en (10 live) TLS GZIP Signed-in Token (erlendaakre)
Sep 28, 2021 09:52:33.479 [0x7fb2ca5a7b38] DEBUG - [Transcode] Found session GUID of 9w1klh2c038bqjll7104rfj9 in session start.
Sep 28, 2021 09:52:33.480 [0x7fb2ca5a7b38] DEBUG - [Transcode] TranscodeUniversalRequest: using augmented profile Web
Sep 28, 2021 09:52:33.480 [0x7fb2ca5a7b38] DEBUG - [Transcode] Downloading document http://127.0.0.1:32400/library/metadata/12496?includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=yxyh03haujgvrv6kq3ute83k
Sep 28, 2021 09:52:33.493 [0x7fb2ca5a7b38] DEBUG - [Transcode] We're going to try to auto-select an audio stream for account 1.
Sep 28, 2021 09:52:33.493 [0x7fb2ca5a7b38] DEBUG - [Transcode] Selecting best audio stream for part ID 19803 (autoselect: 1 language: en)
Sep 28, 2021 09:52:33.493 [0x7fb2ca5a7b38] DEBUG - [Transcode] Audio Stream: 28454, Subtitle Stream: -1
Sep 28, 2021 09:52:33.496 [0x7fb2ca5a7b38] DEBUG - [Transcode] MDE: Selected protocol dash; container: mp4
Sep 28, 2021 09:52:33.496 [0x7fb2ca5a7b38] DEBUG - [Transcode] MDE: analyzing media item 19632
Sep 28, 2021 09:52:33.496 [0x7fb2ca5a7b38] DEBUG - [Transcode] MDE: E9 - Scorched Earth: Direct Play is disabled
Sep 28, 2021 09:52:33.496 [0x7fb2ca5a7b38] DEBUG - [Transcode] MDE: E9 - Scorched Earth: media must be transcoded in order to use the dash protocol
Sep 28, 2021 09:52:33.496 [0x7fb2ca5a7b38] DEBUG - [Transcode] MDE: E9 - Scorched Earth: no direct play video profile exists for http/mkv/h264
Sep 28, 2021 09:52:33.496 [0x7fb2ca5a7b38] DEBUG - [Transcode] MDE: E9 - Scorched Earth: no direct play video profile exists for http/mkv/h264/ac3
Sep 28, 2021 09:52:33.496 [0x7fb2ca5a7b38] DEBUG - [Transcode] MDE: E9 - Scorched Earth: no direct play video profile exists for http/mkv/h264/aac
Sep 28, 2021 09:52:33.496 [0x7fb2ca5a7b38] DEBUG - [Transcode] MDE: Cannot direct stream audio stream due to codec ac3 when profile only allows aac
Sep 28, 2021 09:52:33.496 [0x7fb2ca5a7b38] DEBUG - [Transcode] MDE: Stargate SG-1 - S4 E9 - Scorched Earth: selected media 0 / 19632
Sep 28, 2021 09:52:33.496 [0x7fb2ca5a7b38] DEBUG - [Transcode] Streaming Resource: Added session 0x7fb2cac29618:yxyh03haujgvrv6kq3ute83k
Sep 28, 2021 09:52:33.497 [0x7fb2ca5a7b38] DEBUG - [Transcode] Streaming Resource: Reached Decision id=12496 codes=(General=1001,Direct pla
But for the second one that fails, there are two errors:
Sep 28, 2021 09:57:05.892 [0x7fb2ca920b38] ERROR - [Transcode] [FFMPEG] - libva: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
Sep 28, 2021 09:57:05.892 [0x7fb2ca920b38] ERROR - [Transcode] [FFMPEG] - Failed to initialise VAAPI connection: -1 (unknown libva error).
Sep 28, 2021 09:57:05.884 [0x7fb2ca920b38] DEBUG - Request: [192.168.1.110:64606 (Subnet)] GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flibrary%2Fmetadata%2F13015&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=g81uc4t5gdgcw8lr2rf2b5kx&subtitles=burn&Accept-Language=en (6 live) TLS GZIP Signed-in Token (erlendaakre)
Sep 28, 2021 09:57:05.885 [0x7fb2ca920b38] DEBUG - [Transcode] Found session GUID of g81uc4t5gdgcw8lr2rf2b5kx in session start.
Sep 28, 2021 09:57:05.885 [0x7fb2ca920b38] DEBUG - [Transcode] TranscodeUniversalRequest: using augmented profile Web
Sep 28, 2021 09:57:05.885 [0x7fb2ca920b38] DEBUG - [Transcode] Downloading document http://127.0.0.1:32400/library/metadata/13015?includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=syk5rmmq1o19y2qfesz6prai
Sep 28, 2021 09:57:05.891 [0x7fb2ca920b38] DEBUG - [Transcode] We're going to try to auto-select an audio stream for account 1.
Sep 28, 2021 09:57:05.891 [0x7fb2ca920b38] DEBUG - [Transcode] Selecting best audio stream for part ID 20317 (autoselect: 1 language: en)
Sep 28, 2021 09:57:05.891 [0x7fb2ca920b38] DEBUG - [Transcode] Audio Stream: 29800, Subtitle Stream: -1
Sep 28, 2021 09:57:05.892 [0x7fb2ca920b38] DEBUG - [Transcode] Codecs: testing h264_vaapi (encoder)
Sep 28, 2021 09:57:05.892 [0x7fb2ca920b38] DEBUG - [Transcode] Codecs: hardware transcoding: testing API vaapi
Sep 28, 2021 09:57:05.892 [0x7fb2ca920b38] DEBUG - [Transcode] Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: I/O error
Sep 28, 2021 09:57:05.892 [0x7fb2ca920b38] DEBUG - [Transcode] Codecs: testing h264_nvenc (encoder)
Sep 28, 2021 09:57:05.892 [0x7fb2ca920b38] DEBUG - [Transcode] Codecs: hardware transcoding: testing API nvenc
Sep 28, 2021 09:57:05.892 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded lib: libcuda.so.1
Sep 28, 2021 09:57:05.892 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuInit
Sep 28, 2021 09:57:05.892 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuDeviceGetCount
Sep 28, 2021 09:57:05.892 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuDeviceGetAttribute
Sep 28, 2021 09:57:05.892 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuDeviceGetName
Sep 28, 2021 09:57:05.892 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuDeviceComputeCapability
Sep 28, 2021 09:57:05.892 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuCtxCreate_v2
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuCtxSetLimit
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuCtxPushCurrent_v2
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuCtxPopCurrent_v2
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuCtxDestroy_v2
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuMemAlloc_v2
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuMemAllocPitch_v2
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuMemsetD8Async
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuMemFree_v2
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuMemcpy2D_v2
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuMemcpy2DAsync_v2
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuGetErrorName
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuGetErrorString
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuCtxGetDevice
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuStreamCreate
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuStreamQuery
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuStreamSynchronize
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuStreamDestroy_v2
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuStreamAddCallback
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuEventCreate
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuEventDestroy_v2
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuEventSynchronize
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuEventQuery
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuEventRecord
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuLaunchKernel
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuLinkCreate
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuLinkAddData
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuLinkComplete
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuLinkDestroy
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuModuleLoadData
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuModuleUnload
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuModuleGetFunction
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuTexObjectCreate
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuTexObjectDestroy
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuGLGetDevices_v2
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuGraphicsGLRegisterImage
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuGraphicsUnregisterResource
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuGraphicsMapResources
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuGraphicsUnmapResources
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuGraphicsSubResourceGetMappedArray
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Cannot load optional cuDeviceGetUuid
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Cannot load optional cuImportExternalMemory
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Cannot load optional cuDestroyExternalMemory
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Cannot load optional cuExternalMemoryGetMappedBuffer
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Cannot load optional cuExternalMemoryGetMappedMipmappedArray
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuMipmappedArrayGetLevel
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuMipmappedArrayDestroy
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Cannot load optional cuImportExternalSemaphore
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Cannot load optional cuDestroyExternalSemaphore
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Cannot load optional cuSignalExternalSemaphoresAsync
Sep 28, 2021 09:57:05.893 [0x7fb2ca920b38] DEBUG - [Transcode] [FFMPEG] - Cannot load optional cuWaitExternalSemaphoresAsync
Anyone got a clue on what might be causing this?
The same episodes were playing just fine before I upgraded ubuntu.
Full log file:
Successful video playback at 09:52.
Failed video playback at 09:57.
Plex Media Server.log (363.7 KB)
Solved.
Upgrading to the latest Nvidia drivers (470) did the trick, server is now back to it’s good old self. leaving the post in case anyone has the same error
Thanks for posting this; it’d been driving me crazy for a few weeks and I finally got around to looking at it. Updating Nvidia drivers from 340 (I think) to 470 followed by a restart did the trick.
For anyone unsure where to do this, open Ubuntu’s software updater and find the “Additional Drivers” section.
So am I understanding this correctly? My plex server that has been running fine for several years now requires a VIDEO CARD upgrade so I can play my existing files? My video card is not supported by recent drivers and I have no desire to buy a new one.
Would someone kindly clarify this please? I have had a “Lifetime Plex Pass” for as long as I can remember and I have never ran into an issue such as this before.
If necessary, how do I roll-back to a working version? I just noticed this recently. I have no idea how long ago the change was implemented.
I tried moving to plexmediaserver_1.25.0.5246-cb2507e4d_amd64.deb but it does not seem to have made a difference.
@koakawe
Please explain the hardware you have.
Also please show the DEBUG log files which have captured your problem.
What you’ve stated here isn’t enough to even answer properly.
