May I Check if someone can help me with this please?
TS-451
4.2.2 Build 20161208
Fowarded all relevant ports
Unable to Start PMS still
[~] # $(getcfg -f /etc/config/qpkg.conf PlexMediaServer Install_path)/plex.sh st op
Plex Media Server hasn’t been enabled or started …
[~] # rm “$(getcfg -f /etc/config/qpkg.conf PlexMediaServer Install_path)/Librar y/Plex Media Server/plexmediaserver.pid”
rm: cannot remove `/share/CACHEDEV5_DATA/.qpkg/PlexMediaServer/Library/Plex Medi a Server/plexmediaserver.pid’: No such file or directory
[~] # $(getcfg -f /etc/config/qpkg.conf PlexMediaServer Install_path)/plex.sh st art
Starting Plex Media Server…
[~] # Error: Unable to set up server: bind: Address already in use (N5boost16exc eption_detail10clone_implINS0_19error_info_injectorINS_6system12system_errorEEEE E)
Have tried the above advice with Terminal - but getting this :
Plex Media Server is currently running or hasn’t been shutdown properly. Please stop it before starting a new instance.
If not so, then delete the file named /share/HDA_DATA/.qpkg/PlexMediaServer/lock and try again.
Can anyone help……
My Plex Server was running great until I applied the Plex Update 1.7.2.3878 and the QNAP update 4.3.3.0188. Not sure which one caused this problem. The QNAP NAS box is up and running and all seems OK other than the Plex Media Server won’t start. Trying to access it through a Windows 10 terminal but get the “error connection refused”.
Running Plex media Server Version: 1.7.2.3878
Running On QNAP TS-451+ Ver. 4.3.3.0188
IP Address 192.168.1.245:32400
PuTTy Results:
[~] # $(getcfg -f /etc/config/qpkg.conf PlexMediaServer Install_path)/plex.sh stop
[~] # rm “$(getcfg -f /etc/config/qpkg.conf PlexMediaServer Install_path)/Library/Plex Media Server/plexmediaserver.pid”
rm: can’t remove ‘/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/plexmediaserver.pid’: No such file or directory
[~] # $(getcfg -f /etc/config/qpkg.conf PlexMediaServer Install_path)/plex.sh start
/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/plex.sh: line 39: ./Plex Media Server: No such file or directory
Any suggestions on how to get it working again would sure be appreciated…
I know this is old but I’m wondering if it still works? I have a new tvs-471 and I’ve uploaded the 64bit version for QTS 4.3 but I still can’t get plex to work. My firmware is up to date with 4.3.3. Any help would be greatly appreciated.
Maybe I’m not being clear. That webpage is what I see when I click on the plex app on the qnap dashboard. I’m not selecting an ip. I’m pretty new to all of this, so I could be messing up here but I wanted to be clear.
Wayne, Yes PMS administration is through the browser always.
Once you have it fully configured the way you want it, then feel free to use the app as much as you want. The app only provides playback and sync capabilities. It doesn’t provide any administration capabilities.
