Everything works, except video playback
Everyone here seems to be having the same issues but no one is giving a solution to the problem. It also seems that the people that are having issues are the ones with windows computers. If it doesn't work yet for windows computer than that info should be provided unless someone in this forum got it working on a windows 7/8 "ATV3" and can provide the steps to get it working. Thanks
One of the developers is using windows as his machine so it does work on windows.
Also you have not provided the info requested to help troubleshoot (i removed your previous post because it was clogging up the forum when you should have used pastebin as requested) so please do not whine.
Is not whining and my comment is not for you removing the post. Is that I don't see no one giving any solutions on how to fix the problem. Even those people that gave the info you looking for still no solution.
Patience, we will get to the bottom of it.
My point is that you are asking me to help you fix your problem, which may or may not have the same root issue as the others in this thread but you have not provided any information to determine that or help us get to the bottom of it (we have already seen one user realise that it was a SMB issue for him and not a common cause).
  • TV2 or ATV3?: ATV3
  • Your ATV firmware version (found under the ATV settings > general > about > Apple TV software): 5.2.1
  • The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.2.112
  • The device and operating system (including version number) that PlexConnect is installed on: Windows 7/8
  • The local IP address of the device that PlexConnect is installed on: 192.168.2.112
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on:Windows 7/8
  • The local IP address of the device that the Plex media server (PMS) is installed on:192.168.2.112
  • Where your media is stored (e.g. internal drive) internal
  • The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one: Elan and Plexlnc and ibaa
this is my cmd:
http://pastebin.com/dbdRE2Kv
after i trying to load 2 movies the atv3 write me "access to trailers" and loading 10 minutes after that is write my "unavailable trailers try again later"
ranran you are running 2 different operating systems, are you using VMWare or similar to run either of them?
Please post the settings.py of your iBaa branch.
Are you running windows firewall and have you tried disabling it?
Can you post a screenshot of the point where you are browsing your library and on the pre-play screen?
i have the Same issue, but running OSX 10.8.3…
No Solution until yet.
BR
Peter
  • ATV 3 Firmware 5.2.1
  • DNS Server on ATV 192.168.1.139
  • Windows 7 Ultimate Service Pack 1
  • Local IP For Plexconnect 192.168.1.139
  • Local IP for pms 192.168.1.139
  • External Drive
  • iBaa latest release
  • http://pastebin.com/3Am9keB4 (Detail for media file)
  • No images for the movies and after loading for more than 10 minutes error
  • http://pastebin.com/QdrvvfME (termial/cmd window)
  • External Drive
Settings.cfg file content
PlexConnect]
port_pms = 32400
enable_plexgdm = True
ip_pms = 192.168.178.10
ip_dnsmaster = 8.8.8.8
enable_dnsserver = True
http://pastebin.com/pXcbynKA (terminal/cmd window) different movie played
Over 15 minutes i get in ATV "An error occured loading this content.
Puchdog, what happens if you hard code your PlexConnect IP in the settings.cfg file? (TBH i do not think it will make any difference but i want to rule it out).
The info you gave is really good though and i will discuss with Baa and Roidy as there is something weird going on there.
Could you take a screenshot of the section/pre-play screen, i am interested to see what it looks like with metadata but no pictures?
Oh and one more questions:
- how are you downloading the source code e.g. using github or by just downloading and extracting the zip?
I downloaded and extracted the file.
You don't have a TV show section?
Is it because all I loaded to my pms is movies and music. No tv shows
You have the devs stumped on this at the moment.
Could you do two things:
1> Check what agent you have set to scrape for movies and then post a screen shot of the setup/ordering of them like:
2> Try adding in a TV show section with even just one media file (you can always rename a movie file to e.g. game of thrones s01e01)
The next thing I will do is the tv show
That's what mine is doing, but when I load the actual title it brings everything up except the picture then gives the loading error when you try to play the media
iv been going through the cmd commands and I cant see anything funky going on and I have the tv section.
here is what I have ruled out so far;
various different meta setups
uninstalled and reinstalled
uninstalled and re-installed with connect in root plex directory
deleting the library and re searching
running plex as full admin
releasing and renew IP's
reset of router
reset of DNS
full reboot of apple TV 3
changed transcode settings
changed streaming bit rate
Update of firmware to latest OS ( then all of the above again)
I have also monitored the router traffic while trying to load in conjunction with the terminal window, there is traffic there but it just doesn't seem to be fully loading
Hope this speeds things up
P
terminal window, running W8 Pro
Pablo what section do you have (tv/home movies/movies)?
orig boot
