Everything works, except video playback
Trial of ready made Windows image:
http://www.vmware.com/landing_pages/fusion-trial-vms.html
Trial of workstation to use with the above:
https://my.vmware.com/web/vmware/evalcenter?p=vmware-workstation9
Teminal/cmd for movie section in folders http://pastebin.com/6zPeFfYi
Could someone with the missing cover art problem please try the following:-
1. On the same machine that PlexConnect is running on, open the Plex web interface in a browser, go to a movie and press the little (i) button at the bottom of the left toolbar.
2. From the popup window press "View XML" at the bottom.
3.In the browser page that opens up find the thumb key, enter the last part, in this case /thumb/1370374865 into the end of the address that's already in the address bar and press enter.
If the image is displayed then the problem is with PlexConnect, however if the image is not displayed then the problem is with the connection between the PlexConnect machine and the PMS, may be a firewall issue.
When I get VMWare up and running do i need to start a new PMS?
If the image is displayed then the problem is with PlexConnect, however if the image is not displayed then then problem is with the connection between the PlexConnect machine and the PMS, may be a firewall issue.
I just did the following and the image came up in the browser.
I got the VMWare running if I need to start from scratch let me know.
Could you edit Setting.cfg and change:-
enable_plexgdm = True
to
enable_plexgdm = False
and
ip_pms = 192.168.178.10
to
the ip address of your PMS.
save the file and rerun PlexConnect.
I will try when I get back home.
I tried it already, no change
to
and
to
I tried, nothing
ok checked IE the Proxy isn't running
also just so you know, standard home sharing through iTunes still works and is displaying the art work
Could you go into services and check windows activation services, if it is running try disabling it.
Could you also confirm that what version of Python you are running (version number and 32/64 bit please?)
It works! The new version of ibaa
Thanks for all
The one that was just released today?
Could others please confirm that it is now working?
Just as i had installed windows on a machine to try and see if i could reproduce the issue!
yes the new version that release today from ibaa
The new file do we downloaded from iBaa Github site?
https://github.com/iBaa/PlexConnect/archive/XML_templates.zip
Delete your older folder and replace with the one from the link above.
Do any of the files need to be modified in this version? It looks like I'm still having the same problem. I don't have art work and I'm stuck in "accessing trailers".
