Failed to download subtitle
PMS v1.41.0.8992 on Synology DSM 7 fully updated.
Plex Web v4.136.1
Plex Media Server Logs_2024-09-21_20-56-32.zip (4.2 MB)
Please help.
I am also having this issue now.
I had this issue start for me a month ago of so. It worked flawlessly before that for four years. This is a real pain as my wife is from Brazil and the subtitles are a big help for her enjoyment.
I use the download subtitles feature every day. As of yesterday this problem has started. No matter what subtitle I pick, it fails to download and gives an error message.
Same for me, no subs works it just fails no matter what u chose… dont know how fix this
Did it just start for you a few days ago?
yes noticed some days ago. app is fully updated computer also.
Just noticed I am having this problem now too. Started recently in the last week or two.
server version: 1.41.3.9314 on docker
web version: 4.141.0
edit 2024-12-28: started working again with no changes.
Hello,
in the logs I’m getting the following error.
Server-version 1.41.3.9314-a0bfb8370
Web Version 4.141.0
Dec 28, 2024 22:38:09.098 [140418072021816] DEBUG - Request: [192.168.1.35:51690 (Subnet)] OPTIONS /library/metadata/7503/subtitles?key=%2Flibrary%2Fstreams%2F41897&codec=srt&language=eng&hearingImpaired=0&forced=0&providerTitle=OpenSubtitles (5 live) #1b2 TLS GZIP Signed-in Token ()
Dec 28, 2024 22:38:09.098 [140418125400888] DEBUG - Completed: [192.168.1.35:51690] 200 OPTIONS /library/metadata/7503/subtitles?key=%2Flibrary%2Fstreams%2F41897&codec=srt&language=eng&hearingImpaired=0&forced=0&providerTitle=OpenSubtitles (5 live) #1b2 TLS GZIP 0ms 364 bytes (pipelined: 1)
Dec 28, 2024 22:38:09.101 [140418072021816] DEBUG - Request: [192.168.1.35:51690 (Subnet)] PUT /library/metadata/7503/subtitles?key=%2Flibrary%2Fstreams%2F41897&codec=srt&language=eng&hearingImpaired=0&forced=0&providerTitle=OpenSubtitles (5 live) #1be TLS GZIP Signed-in Token (plexuser) (mycomputer)
Dec 28, 2024 22:38:09.116 [140418072021816] DEBUG - [Req#1be] Activity: registered new activity e2f94286-c384-42af-8587-1fafd237c472 - "Downloading Subtitle"
Dec 28, 2024 22:38:09.117 [140418093366072] DEBUG - [Req#1be] Downloading subtitle from https://metadata.provider.plex.tv/library/streams/3085702?X-Plex-Api-Token=xxxxxxxxxxxxxxxxxxxx
Dec 28, 2024 22:38:09.118 [140418127510328] DEBUG - Completed: [192.168.1.35:51690] 200 PUT /library/metadata/7503/subtitles?key=%2Flibrary%2Fstreams%2F41897&codec=srt&language=eng&hearingImpaired=0&forced=0&providerTitle=OpenSubtitles (5 live) #1be TLS GZIP 17ms 411 bytes (pipelined: 2)
Dec 28, 2024 22:38:09.176 [140418093366072] DEBUG - [Req#1be] Got a subtitle of 99 bytes.
Dec 28, 2024 22:38:09.177 [140418093366072] DEBUG - [Req#1be] Activity: Ended activity e2f94286-c384-42af-8587-1fafd237c472.
Dec 28, 2024 22:38:11.202 [140418072021816] DEBUG - [Req#1bd] [PlexRelay] Transferred: sent 22012, received 7144 bytes, in 321.1 seconds
Dec 28, 2024 22:38:11.204 [140418072021816] DEBUG - [Req#1cc] [PlexRelay] Bytes per second: sent 68.6, received 22.2
Dec 28, 2024 22:38:11.206 [140418137873208] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Relay' exit code for process 2414 is 255 (failure)
Looking at the server side everything seems to be in order.
  • Restarted the plexmediaserver ā€œservice plexmediaserver restartā€ no issues found.
  • Checked all DNS server in the network config all are resolving.
Any ideas?
Super annoying, can’t believe the original issue is over a year old now!
Started having this issue as of today aswell.
I believe this has something to do with either some kind of central rate limiting or other issue between plex and opensubtitles.
I’m in GMT and I couldn’t get any subs in the evening yesterday. It’s morning now, and it works. I’ve also checked this two days ago and it was the same.
There is one log entry that says something like ā€œsubtitles downloaded (99 bytes received)ā€
but it probably returns an error message in the body instead.
I tried to do some troubleshooting but now everything works so can’t see the error.
Will try again in the evening when I expect the subtitles not working again.
Also I came across post about entering some opensubtitles credentials somewhere. I don’t think it’s still a thing with recent versions of Plex.
When you get the error, try finding the entry in the log:
Google how to get you Plex API token and try that request in the browser.
Notice that in order to download a subtitle, the request goes through plex servers (metadata.provider.plex.tv). I believe that’s where the bottleneck is.
I’ve been getting a lot of these errors with subtitles as well… :neutral_face:
Adding another report for this issue. It seems to affect me intermittently. This time I got frustrated and did some digging. I wasn’t able to to find a solution but I did fint this in the OpenSubtitles agent log.
Running PMS Version 1.41.3.9314 on a QNAP NAS, connecting with Plex windows app and Plex google tv app.
2024-06-13 19:00:24,017 (7f56650a0808) :  INFO (core:349) - Starting framework core - Version: 2.6.3, Build: 5070ad4 (Fri Nov 25 06:22:39 UTC 2022)
2024-06-13 19:00:24,018 (7f56650a0808) :  DEBUG (core:361) - Using the standard policy
2024-06-13 19:00:24,018 (7f56650a0808) :  DEBUG (core:450) - Starting runtime component.
2024-06-13 19:00:24,019 (7f56650a0808) :  DEBUG (core:450) - Starting caching component.
2024-06-13 19:00:24,019 (7f56650a0808) :  DEBUG (core:450) - Starting data component.
2024-06-13 19:00:24,019 (7f56650a0808) :  DEBUG (core:450) - Starting networking component.
2024-06-13 19:00:24,020 (7f56650a0808) :  DEBUG (networking:265) - No cookie jar found
2024-06-13 19:00:24,035 (7f56650a0808) :  DEBUG (networking:428) - Setting the default network timeout to 20.0
2024-06-13 19:00:24,036 (7f56650a0808) :  DEBUG (core:450) - Starting localization component.
2024-06-13 19:00:24,036 (7f56650a0808) :  INFO (localization:409) - Setting the default locale to en-us
2024-06-13 19:00:24,036 (7f56650a0808) :  DEBUG (localization:427) - Loaded en strings
2024-06-13 19:00:24,036 (7f56650a0808) :  DEBUG (core:450) - Starting messaging component.
2024-06-13 19:00:24,037 (7f56650a0808) :  DEBUG (core:450) - Starting debugging component.
2024-06-13 19:00:24,037 (7f56650a0808) :  DEBUG (core:450) - Starting services component.
2024-06-13 19:00:24,037 (7f56650a0808) :  DEBUG (core:450) - Starting myplex component.
2024-06-13 19:00:24,037 (7f5661cceb38) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/system/messaging/clear_events/com.plexapp.agents.opensubtitles'
2024-06-13 19:00:24,037 (7f56650a0808) :  DEBUG (core:450) - Starting notifications component.
2024-06-13 19:00:24,173 (7f56650a0808) :  DEBUG (accessor:68) - Creating a new model access point for provider com.plexapp.agents.opensubtitles in namespace 'metadata'
2024-06-13 19:00:24,179 (7f56650a0808) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/resourceHashes'
2024-06-13 19:00:24,185 (7f56650a0808) :  ERROR (networking:196) - Error opening URL 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/resourceHashes'
2024-06-13 19:00:24,187 (7f56650a0808) :  CRITICAL (runtime:1299) - Exception getting hosted resource hashes (most recent call last):
  File "/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-5070ad484/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/runtime.py", line 1293, in get_resource_hashes
    json = self._core.networking.http_request("http://127.0.0.1:32400/:/plugins/com.plexapp.system/resourceHashes", timeout=10).content
  File "/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-5070ad484/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 242, in content
    return self.__str__()
  File "/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-5070ad484/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 220, in __str__
    self.load()
  File "/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Plug-ins-5070ad484/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 158, in load
    f = self._opener.open(req, timeout=self._timeout)
  File "/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Python/python27.zip/urllib2.py", line 435, in open
    response = meth(req, response)
  File "/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Python/python27.zip/urllib2.py", line 548, in http_response
    'http', request, response, code, msg, hdrs)
  File "/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Python/python27.zip/urllib2.py", line 473, in error
    return self._call_chain(*args)
  File "/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Python/python27.zip/urllib2.py", line 407, in _call_chain
    result = func(*args)
  File "/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Resources/Python/python27.zip/urllib2.py", line 556, in http_error_default
    raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
HTTPError: HTTP Error 404: Not Found
2024-06-13 19:00:24,196 (7f5661aaab38) :  DEBUG (services:265) - Plug-in is not daemonized - loading services from system
2024-06-13 19:00:24,196 (7f56650a0808) :  DEBUG (runtime:1117) - Created a thread named 'load_all_services'
2024-06-13 19:00:24,197 (7f56650a0808) :  DEBUG (runtime:1117) - Created a thread named 'get_server_info'
2024-06-13 19:00:24,197 (7f5661aaab38) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_'
2024-06-13 19:00:24,197 (7f5661a1db38) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400'
2024-06-13 19:00:24,198 (7f56650a0808) :  DEBUG (core:150) - Finished starting framework core
2024-06-13 19:00:24,199 (7f56650a0808) :  DEBUG (core:560) - Loading plug-in code
2024-06-13 19:00:24,250 (7f5661a1db38) :  DEBUG (core:538) - Machine identifier is 0a9d2c021ec3817e20e24d4e71376be39c6051cc
2024-06-13 19:00:24,261 (7f5661a1db38) :  DEBUG (core:539) - Server version is 1.30.0.6442-5070ad484
2024-06-13 19:00:24,262 (7f5661aaab38) :  DEBUG (services:362) - Loaded services
2024-06-13 19:00:24,275 (7f5661a40b38) :  DEBUG (services:438) - No shared code to load
2024-06-13 19:00:24,290 (7f56650a0808) :  DEBUG (core:566) - Finished loading plug-in code
2024-06-13 19:00:24,302 (7f56650a0808) :  DEBUG (agentkit:1132) - Creating new agent class called OpenSubtitlesAgentMovies
2024-06-13 19:00:24,302 (7f56650a0808) :  DEBUG (agentkit:937) - Updating agent information: [{'media_types': ['Movie'], 'accepts_from': None, 'fallback_agent': None, 'contributes_to': ['com.plexapp.agents.imdb'], 'languages': ['xn'], 'persist_stored_files': True, 'version': 0, 'primary_provider': False, 'prefs': True, 'name': 'OpenSubtitles.org'}]
2024-06-13 19:00:24,303 (7f56650a0808) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQo2CmRpY3QKbGlzdApkaWN0Cmxpc3QKbGlzdApsaXN0CjIKczMyCmNvbS5wbGV4YXBwLmFnZW50cy5vcGVuc3VidGl0bGVzczEwCmlkZW50aWZpZXJyMQpzMTAKYWdlbnRfaW5mbzEKcjIKMTAKcjMKczExCm1lZGlhX3R5cGVzbnMxMgphY2NlcHRzX2Zyb21uczE0CmZhbGxiYWNrX2FnZW50cjQKczE0CmNvbnRyaWJ1dGVzX3RvcjUKczkKbGFuZ3VhZ2VzYjFzMjAKcGVyc2lzdF9zdG9yZWRfZmlsZXNpMApzNwp2ZXJzaW9uYjBzMTYKcHJpbWFyeV9wcm92aWRlcmIxczUKcHJlZnNzMTcKT3BlblN1YnRpdGxlcy5vcmdzNApuYW1lMQpzNQpNb3ZpZTEKczIzCmNvbS5wbGV4YXBwLmFnZW50cy5pbWRiMQpzMgp4bnIwCg__'
2024-06-13 19:00:24,309 (7f56650a0808) :  DEBUG (agentkit:1132) - Creating new agent class called OpenSubtitlesAgentTV
2024-06-13 19:00:24,310 (7f56650a0808) :  DEBUG (agentkit:937) - Updating agent information: [{'media_types': ['Movie'], 'accepts_from': None, 'fallback_agent': None, 'contributes_to': ['com.plexapp.agents.imdb'], 'languages': ['xn'], 'persist_stored_files': True, 'version': 0, 'primary_provider': False, 'prefs': True, 'name': 'OpenSubtitles.org'}, {'media_types': ['TV_Show'], 'accepts_from': None, 'fallback_agent': None, 'contributes_to': ['com.plexapp.agents.thetvdb'], 'languages': ['xn'], 'persist_stored_files': True, 'version': 0, 'primary_provider': False, 'prefs': True, 'name': 'OpenSubtitles.org'}]
2024-06-13 19:00:24,310 (7f56650a0808) :  DEBUG (networking:143) - Requesting 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0FnZW50U2VydmljZTpVcGRhdGVJbmZv/Y2VyZWFsMQoxCmxpc3QKMApyMAo_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__'
2024-06-13 19:00:24,318 (7f56650a0808) :  INFO (datakit:118) - No default dictionary file
2024-06-13 19:00:24,319 (7f56650a0808) :  INFO (datakit:131) - Saved the dictionary file
2024-06-13 19:00:24,319 (7f56650a0808) :  INFO (core:611) - Started plug-in
2024-06-13 19:00:24,319 (7f56650a0808) :  DEBUG (socketinterface:160) - Starting socket server
2024-06-13 19:00:24,320 (7f56650a0808) :  DEBUG (runtime:1117) - Created a thread named 'start'
2024-06-13 19:00:24,320 (7f56650a0808) :  INFO (socketinterface:184) - Socket server started on port 38771
2024-06-13 19:00:24,320 (7f56650a0808) :  INFO (pipeinterface:25) - Entering run loop
2024-06-13 19:00:24,320 (7f56650a0808) :  DEBUG (runtime:717) - Handling request GET /:/prefixes
2024-06-13 19:00:24,322 (7f56650a0808) :  DEBUG (runtime:814) - Found route matching /:/prefixes
2024-06-13 19:00:24,322 (7f56650a0808) :  DEBUG (runtime:924) - Response: [200] MediaContainer, 157 bytes
I have run into the same issue again. Hope it will be fixed soon.
I’m getting something like this when i try to download subtitles:
Jan 19, 2025 21:54:03.455 [140536665930552] Debuguj — Request: [10.0.20.236:34426 (Allowed Network (WAN))] PUT /library/metadata/15727/subtitles?codec=srt&key=%2Flibrary%2Fstreams%2F72719&language=pol&providerTitle=OpenSubtitles (14 live) #1ea19 TLS GZIP Signed-in Token (jerry1333) (BRAVIA VH2) / Accept-Encoding => gzip / Accept-Language => pl-pl / Connection => Keep-Alive / Content-Length => 0 / Content-Type => application/x-www-form-urlencoded / Host => 10.0.30.2:32400 / User-Agent => Mozilla/5.0 (Linux; Android 10; BRAVIA 4K VH2 Build/QTG3.200305.006.S414; wv)PlexTV/10.24.1.2319 / X-Plex-Advertising-DoNotTrack => 0 / X-Plex-Advertising-Identifier => xxx / X-Plex-Client-Identifier => xxx / X-Plex-Device => BRAVIA 4K VH2 / X-Plex-Device-Name => BRAVIA VH2 / X-Plex-Device-Screen-Density => 320 / X-Plex-Device-Screen-Resolution => 1920x1080 (tv) / X-Plex-Device-Vendor => Sony / X-Plex-DRM => widevine:video / X-Plex-Features => external-media,indirect-media,hub-style-list / X-Plex-Language => pl-pl / X-Plex-Model => BRAVIA_VH2 / X-Plex-Platform => Android / X-Plex-Platform-Version => 10 / X-Plex-Product => Plex for Android (TV) / X-Plex-Provider-Version => 7.2.0 / X-Plex-Provides => controller / X-Plex-Session-Id => xxx / X-Plex-Token => xxxxxxxxxxxxxxxxxxxx / X-Plex-Version => 10.24.1.2319
Jan 19, 2025 21:54:03.461 [140536665930552] Debuguj — [Req#1ea19] Activity: registered new activity 1dcf377f-181d-440d-8d6a-c737b34fadf2 - "Downloading Subtitle"
Jan 19, 2025 21:54:03.462 [140536578005816] Debuguj — [Req#1ea19] Downloading subtitle from https://metadata.provider.plex.tv/library/streams/10238219?X-Plex-Api-Token=xxxxxxxxxxxxxxxxxxxx
Jan 19, 2025 21:54:03.462 [140536785414968] Debuguj — Completed: [10.0.20.236:34426] 200 PUT /library/metadata/15727/subtitles?codec=srt&key=%2Flibrary%2Fstreams%2F72719&language=pol&providerTitle=OpenSubtitles (14 live) #1ea19 TLS GZIP 6ms 298 bytes (pipelined: 1)
Jan 19, 2025 21:54:03.718 [140536578005816] Debuguj — [Req#1ea19] Got a subtitle of 35 bytes.
Jan 19, 2025 21:54:03.718 [140536578005816] Debuguj — [Req#1ea19] Activity: Ended activity 1dcf377f-181d-440d-8d6a-c737b34fadf2.
But on screen I see Something is wrong… etc. and no subtitles for me :frowning:
Same here, it started to do yesterday, i just reinstall the whole system in Docker, today worked well during hours, and bumm now it’s broken again. ANy idea???
Happy to have found this but concerned since the first post was years ago. I just noticed I have this issue today. Can’t get subtitles. Not sure when exactly it started happening because I can’t recall when I grabbed one last but none of the presented subtitles will download
Same here. As others, I see that a very small subtitle file was doownloaded. 99-byte subtitle file is too small to be valid. It seems there is something wrong with subtitle service. Hope it gets fixed soon.
exact same issue for me, I am even premium opensubtitles, VIP. tried checking all the logs, no help
