Server Version#: 1.18.7.2457
Player Version#: 7.28.0.15501
I have recently noticed that the recommended h264 level is 1.0 on the Fire 4k devices and now these devices are transcoding the 4k files to 1080p.
I have settings correct, so MAXIMUM or ORIGINAL on the video and audio, with Passthrough as HDMI. Playing with these settings make no difference.
No matter which Fire device, I get the same issue and it has only recently started.
Any ideas?
nx6
2
Did you set the Fire Stick 4K’s level back where it should be (L 5.2)?
tried at 5.2 and also 5.1 (which is what I have always had it as).
My Shield is set to 5.1 and does not have this issue.
I am having same issue when playing back I get transcode reason: 4K playback is not supported on this device.
App updated on 17 February.
7.28.0.15501 (ba34f115)
emuhack
6
Same… Super frustrating!!!
Me also, but it stills says that the 1.0 is recommended for this device. This better get fixed fast
system
Closed
9
