jhr
1
Using Plex 1.7.6 when I fix a wrong match of an album the tracks are not refreshed.
It seems difficult to edit them manually one by one to fix them.
I tried to refresh metadata or re-analyze but they do not refresh, is there a way to force a new refresh/update of the tracks ?
Otherwise is there a way to ignore the online-retrieved tracks data (from the match) and to only use the data in the FLAC ?
Make it so as if Plex has never seen those files.
Like so: Plex Dance (with music, step 4 can be omitted)
Sure:
- edit the library,
go to the ‘Advanced’ tab and check ‘use embedded meta data’
- go to Settings - Server - Agents - Albums - last.fm/Premium Music
drag the line ‘Local Media Assets’ to the very top of the ‘stack’ of agents
