Hauppauge wintv-dualhd not being detected after 7.2 shield update
If you recently updated your shield to 7.2 this will be the reason.
Myself and various other users have posted the issue.
Same here, I’ve purchased and installed Hauppauge Win-TV Dual-HD (model 1590) in my Nvidia Shield 2017 and it does not find it!. According to specs its fully compatible and I can see it just fine in windows 10, but not on Nvidia Shield! I use the latest Plex app and Plex Server.
Any suggestions?
Someone from Plex support?
Hi again,
I’ve also created a post in Forum Feedback about this issue:
BUG! Hauppauge Win-TV Dual-HD (model 1590) can not be discovered anymore in Nvidia Shield PLEX Server latest edition!
I hope someone from PLEX notices it!
FORWARDED THIS IN:
Thanks for reporting the issue after the 7.2 Shield Update. Will have it looked into
Thank you.
I’m looking into this right now, but it’s functioning correctly here for me. I’m testing with a 500GB SHIELD, upgraded to 7.2 just now, with a WinTV DualHD 1595. The 1595 is the US ATSC/QAM model, so it’s entirely possible that they broke the DVB-T model with the latest SHIELD update.
That said, it definitely should be working. Can you give me a full set of the PMS/PTS logs? I see that same libusb error in my log, so the fact that it’s displaying for you is probably a red herring. Usually that error message indicates some sort of permissions error on a USB device, but with it working correctly for me I’m not that concerned about it. Unfortunately there’s also no rooted 7.2 build yet so I can’t look at system logs on my SHIELD to figure out why it’s printing that out.
Here’s my server logs. Hope this helps.
Plex Media Server Logs_2018-12-20_13-00-24.zip (2.0 MB)
Gents, my Nvidia just updated to 7.2.1, but no joy. I’m using a PCTV 292e tuner, attached are my logs if it helps Plex Media Server Logs_2018-12-20_19-23-54.zip (597.2 KB)
Just as a heads up, we reported this to Nvidia and they’re investigating from their side as well.
@timwoj Just wondering how it’s going in terms of fixing the issue, as well as what specifically caused the bug. Take all the time you need in fixing it, I just want to know when I can record things again. Thanks!
Same problem, tuner is not detected after the 7.2 shield update
It is still not working on my Shield even after the 7.2.1 update.
Thanks for your logs. Is it the dualHD 1590 or 1595? All other users i checked so far are in Europe - which I believe is the WinTV dualHD 1590 european model.
Mine is indeed the WinTV dualHD 1590. I am based in the UK.
I have gone through the list and everyone apart from one is Europe based - so need to clarify the anomaly
So please could each who has not provided the model number - please do
The 1590 is the Europe DVB-T model.
Server Version#:1.14.0.5470 (smb)
Player Version#:7.8.2.8255 (fa7afda5)
Recently updated Nvidia Shield to Shield Experience 7.2 - now Hauppage Win TV dualHD TV Tuner is no longer found - has this functionality been broken?
Plex DVR stopped working. Deleted DVR, tried to re-add it [my tuner is a Hauppage WinTV-dualHD TV Tuner]. Plex no longer scans and finds this, and actually now ONLY gives the specific option to find HDHomeRun tuners with the prompt:
ā€œDon’t see your HDHomeRun device? Enter its network address manuallyā€
Unable to alter this.
Personally, I don’t expect a respond to this issue - I never have had one before. I hope that in a few months’ time I discover the Plex has fixed this - please SURPRISE me with a response!
Same - Hauppauge wintv-dualhd not being detected after 7.2 shield update
I have exactly the same problem.
I’m having the same issue, so until the problem is fixed, i’m going to unsubscribe. This started yesterday.
