@paulsalter said:
All Set
Removed all episodes of these shows, emptied trash, cleaned bundles, optimised database, refreshed the EPG and set both these shows to record (all episodes)
I have a feeling Emmerdale is going to have issues, looks like the Gracenote data is wrong
This is tonights episodes, but the details have it as April 2nd, should be March 30th (same for other Emmerdale airings), this is the Freeview EPG
EDIT:Emmerdale EPG looks good from the 4th, so its just the next few days that are wrong
Coronation Street looks good, last nights airing is showing to record at lunchtime and the 2 episodes tonight also look good
Im also using the freeview epg but mine is showing the correct date
It looks like you have something screwy in your epg like me(still doing a refresh here)
That Coronation Street you recorded this afternoon is dated March 30th, it should be March 29th (only one episode last night), does your library inside plex show as 29th or 30th for that Ep?
@paulsalter said:
That episode hasnt aired yet, its on tonight, do tonights episodes look correct in the guide?
That was what i was seeing for Emmerdale, shows where out by a day (airing wise)
My refresh is only 40%, so will see if fixes it
Both coronation streets and the emmerdale for tonight all have todays date so will see how they record think i best delete all the episodes it recorded this afternoon incase it detects it as already recorded
Is this fix for other shows as well? like I have The Big Bang Theory set to record all episodes, and it missed last nights new episode, it also doesn’t show next weeks new episode… used to work… but it records the other non new episodes just fine on other channels, even on the same day.
@“Kings Media” said:
Well the recording emmerdale and coronation street this afternoon didnt work correctly
Emmerdale recorded both episodes but still showing in plex as the same file
and coronation street only recorded 1 episode says 13:15 witch should be part 1 one but plex shows it as part 2
On the Emmerdale icon it is showing two items - would like to see what the stacked 2 items are
So please click on the icon below 1 Episode and shows two items and get me screenshot of the 2 items and also media info xml for each (Get Info / View XML) as outlined here https://support.plex.tv/articles/201998867-investigate-media-information-and-formats/
select all the xml text and copy to separate text file for each
and please the same for the coronation street recording(s)
The EPG Refresh aborted at 55%
Can you get me this file please - zipped C:\Users\drek7\AppData\Local\Temp\44368318-287e-46ef-96a9-bab92ac4b8b4.plex.json
also look for any other xxxxxxxxxxxxxxxxx.plex.json files within the temp folder and zip as well
I just noticed that it recorded both episodes of emmerdale twice this afternoon so might be why its stacked cant do what you have requested as i have no deleted the files so we will have to see what it does tonight when they record
That is fine. Don’t need it.
So to summarise
There were 4 airings of Emmerdale before 7pm
However, the matching against TVDB still has issues. This is statement from our developer
The matching against TVDB is hard because they just mark them as Part 1 and Part 2, and we have no easy way to tell the agent which of those an airing should match to. It’s separate from the issue of it simply not recording at all though. We’ll work on it separately.
(DVR) More fixes around recording multiple airings of a show on the same day (#6668)
This fixes the problem where only one episode was recorded.
There remains an issue with episode identification in the library and that is because of the lack of the detail in the Gracenote data. The airing time is used in this fix to label the episodes differently.
Thanks to @“Kings Media” for the additional user testing for this fix
