How is that possible? Trouble organizing library
Server Version#: 1.23.2.4656
Player Version#: 8.18.2.25850
Hello, first of all I would like to thanks Plex for everything it made possible that I didnt have before it.
So, about the problem, My computer broke, I lost metadata, now Im trying to organize library again, and I’m having a huge problem I can’t solve alone.
To make things simple I will just paste an image, if anyone can help me, because I’m about to lose my mind :expressionless:
here is the picture:
??? I tried inumerous things but I can’t split the files, to epi 1 season 1 go the way its suppose and epi 1 season 2 do the same.
Have you already tried to clean the file names so they match the official schema?
e.g.
P:\Meu Drive\Animes    <- the folder linked to your library
  Nisekoi
    Season 01
      Nisekoi - s01e01.mkv
    Season 02
      Nisekoi - s02e02.mkv
  • try to use 2-digit season numbers (except the season has more than 2 digits) – minor but might helpp causing some mixup
  • include the show name in the episode file names
  • given this is mkv files, embedded metadata should not have an impact
  • make sure there’s no missing / extra folder levels (e.g. don’t point your library at Meu Drive)
I think you nailed it. Different from the Movies agent, the Series one doesn’t allows us to have sub-levels and will consider all those subfolders as one.
I just want to split this files, they are merged in season 1 epi 1
Season 2 is juts not showing up
Yes, they are nailed, how to deploy?
I have 200 other shows that most of them have subfolders and the seasons are correct, but this one was separate season 1 as the anime and season 2 didnt have any match, then I put on the same folder, renamed everything but it continues nailed, I dont see the split apart option
Is your Animes library pointing to P:\Meu Drive\Animes as suggested above ?
Try unmatching that show and matching it again
Yes it is, already unmatch and re-match lot of times… :sob:
Show us this screen - Edit Library/Add Folders:
Ok, well done… now take a screenshot of your show - like this:
Remove the show from the library
Scan Library
Empty Trash:
Repair the names so they ALL look like S02E01 - give them all the show name…
(like it looks in my image)(you don’t need the episode name)
Nisikoi - S02E01.mkv is fine.
When you have all those fixed in Season 01, Season 02 and Specials
Go to Server/Settings/Troubleshooting
Clean Bundles
When that has finished - move the show back to the Library
Scan Library
Let’s hope that fixed it.
Question:
Are all your files mkv files?
or
Do you have some mp4 files?
Alright I will try this, yes everything is mkv, how do I show the extension in explorer? I couldnt find
Folder Options:
‘Uncheck’ “Hide Extensions…”.
I see things are working
Always use the show name
Always have the names correct before you add to the library
If you must rename and it fails:
Plex Dance
In case you think I name all my files by myself - I don’t:
FileBot names everything BEFORE it goes on the server.
:slight_smile:
I was about to go crazy, thanks. :wink:
