Unable to separate files
Server Version#: 1.32.5.7349
Player Version#: Window 10
Hello everyone.
Today I tried to separate two files from two different series, which plex mistakenly merged into a single file. The problem is that the separate option does not appear in the table, as if the file in question were correct.
What can I do ?!
You can only split entire shows, not individual episodes.
If that’s not what you’re looking for, there might be a deeper issue with your file organization or naming.
I explained myself badly. I try to separate the entire Show but it won’t let me because the option is missing in the command box :frowning:
Cases like this usually come down to be caused by bad file naming and folder structure.
This is not the problem. I have been using Plex for quite some time and I have had this library like others for a long time, please note that my database is 40 Tb. I have only recently encountered this anomaly and only on some libraries, always on others as show,no problem :frowning:
Would you mind sharing an example of how your files are named, preferably using the complete path of an episode as well as a pointer to what folder in that hierarchy your library is linked ?
If you deviate from the official naming schema as linked by Otto you can get lucky for a long time… until it suddenly stops working. Hence we usually like to rule out some basic naming issues.
These are the network paths of the two show files that Plex merged:
\FRACTAL\Baghy\Cartoni Animati\I Puffi 2021\Season 01\I Puffi_S01E01_Questione di naso.mp4
\FRACTAL\Baghy\Cartoni Animati\I Puffi 1981\Season 01\s1e1.mp4
This is the library path set to plex:
E:\Cartoni Animati\
I suggest you place the year those shows first aired in brackets:
I Puffi 2021I Puffi (2021)
I Puffi 1981I Puffi (1981)
It might also be worth to check the embedded metadata of both shows in your episode files.
Edit: that being said… there should be an option to split both shows based on the given folder structure. Can you verify you’re actually trying this on the show level? If you’re dealing with a single-season show, you might actually be working on a season record.
I did, but it didn’t change the situation :frowning:
Underscores can cause problems. Use nothing, a dash, or periods instead
I Puffi (2021)\Season 01\I Puffi S01E01 Questione di naso.mp4
I Puffi (1981)\Season 01\S01E01.mp4
s1e1 ← Not supported
I would take both shows out and add the tvdb id.
Plex dance ← click
I Puffi (2021) {tvdb-392426} ← Show folder
I Puffi (1981) {tvdb-75719}
You can split the shows but if you have to rebuild your library or server, whatever is causing this will happen again if you don’t fix the root problem
The strange thing is that it has never given me any problems in the three years that I have been using Plex. However, the only thing that helped me was entering the series number, this way it separated the two shows. Thanks for the help, I will try to change the naming of the files.
