Impossible to connect Plex to my synology NAS
Hello,
I’m new here and I have troubles to connect plex to my NAS. Can you please help me ? In attachment you can see the logs
Server Version#:
Plex Media Server Logs_2021-12-19_18-34-37.zip (79.0 KB)
Would you mind elaborating what exactly you’re trying to achieve?
Is this a newly installed server? – if so, make sure to finish the setup by accessing the server through its local IP address / from within the same network (e.g. http://[Syno IP address]:32400/web)
https://support.plex.tv/articles/200288586-installation/
If you already went through the setup… where exactly are you getting stuck?
You also might want to update your PMS… the version currently installed (1.18.5) is more than 2 years old (latest public version is 1.25.1). You can download the file from Plex’ homepage and use the Manual install option in your Sync’s App Center to update the app. [Edit: noticed in the logs that you had already updated the server app to 1.25.2]
To add to tom80H’s reply,
Review these two documents. They will help you avoid pitfalls when running Plex on Synology NAS.
Installation & Setup of Plex Media Server on Synology
Synology FAQ - Questions, Answers, and a few How-To’s
Thank’s a lot for your answer, I tried with your link and it works now!
Have a nice day :wink:
Thanks for these links, it will help me to be familiar with this tool :wink:
