Server Version#: 1.22.1.4228
Player Version#: 7.15, iOS 14.4.2
Hey there, so here is the problem: in the iOS Plex player app, transcoding options limited to 720p 2mbps or 4K original when using cellular data. Low data consumption mode is turned off, relay turned off, I have full access to my server, and the bug appears only when using the cellular data, wifi works fine. Every cellular data saving option is turned off in plex play. I can choose other transcoding options in the global settings but not individually.
Regards,
Peter
