Linux Tips
Transcoding and tone mapping with JasperLake / ElkhartLake CPUs
This tip / How-To is entirely NOT-SUPPORTED by Plex.
You, as the system’s owner/admin assume all risk/liability for the kernel integrity
It may work for you and it may not. There are no guarantees.
There has been success with for some users. Your results may vary.
This How-To is written for Ubuntu/Debian distributions but should be applicable to others.
  1. Replace inte-media-va-driver with intel-media-va-driver-non-free
  2. As root:
echo "options i915 enable_guc=2" >> /etc/modprobe.d/i915.conf
update-initramfs -u
  1. Restart the host to make active
Forum Reference: Can Jasper Lake N6005 use hardware transcoding?
Back to top
OpenSSL v3.0.0 and PMS.
For those using their own domains and certificates with PMS ,
PMS 1.32.0.6865 and above updates OpenSSL from v1.1.1 to v3.0.0 .
(changed the numbering scheme in the process)
The consequence of this is OpenSSL v3 removed several “less secure” encryption methods.
The impact on you, if you’re using an older distributions where openssl v3 is not the default, if not already doing so, you will need pay special attention to how your certificates are generated
As example, upgrade (specify) a better encryption
PREVIOUS
# Generate  p12 (Acme LE is valid until 2025)
openssl pkcs12 -export -out my-fdqn-tld.p12 \
	-inkey my-fqdn-tld.key -in my-fqdn-tld.crt \
	-certfile CertAuth.crt \
	-password pass:PASSWORD_HERE
IMPROVED
# Generate new p12 (Acme LE is valid until 2025)
	-certpbe AES-256-CBC -keypbe AES-256-CBC -macalg SHA256 \
The key change is to select a better encryption:
To implement
  1. Update certificate creation scripting to include AES-256 (or better) as shown above.
  2. Regenerate P12 file and store where PMS expects it
  3. Restart PMS after updated cert installation ( PMS loads certs at startup only)
The reason for this change is the inevitability of the current libraries being EOL.
Observe:
REF:
Back to top
Certificate problems on new server 1.32.0.6865
Custom PMS SSL Certificate - digital envelope routines::unsupported error SOLUTION
1.32.0.6865 Breaks custom SSL certificate
Certificate error after updating to 1.32
Certificate error accessing plex on windows server x64 xxxx.plex.direct
Custom certificate not working
Plex Media Server v1.32.0.6918 can't use user-provided certificate
SSL Certificate Errors
CERT: incomplete TLS handshake from [::ffff:192.168.1.1]:58888: sslv3 alert certificate unknown (SSL
Plex not picking up any matches as of 3 days ago
Plex not using my SSL Certificate after v1.31.3.6868 (tried 1.32.1.6918 & 1.32.1.6999) on Server22
1.32.x Breaks Plugins on Windows (OpenSSL)
Plex certificate error
"Conversion failed" on multiple clients
PMS SSL Uses *.plex.direct Let's Encrypt SSL certificate instead of custom configured certificate
Custom domain ssl does not work after update to server version 1.32.0.6918
SSL became broken after latest PMS Update
Plex in Docker on VM (ESXi 8.0), using nvidia hardware dec/enc (brand new install)
Issue with i915 transcoding on ubuntu 20.04
CERT: incomplete TLS handshake from - sslv3 alert certificate expired
(RESOLVED) Remote Access failing for 3 days, nothing helping (Day 18)
[SOLVED]'*.plex.direct' SSL Cert miss-match error
Plex Media Server 1.32.0.6918 custom certificate must be regenerated with new OpenSSL arguments
Headless Plexamp using wrong url to connect to PMS
[CERT] TLS connection from 192.168.7.4:2XXX came in with non-plex.direct SNI 'XXXXXX.synology.me'
No server access via VPN
Server showing remote if accessed via internal dns
Plex instance can't scan library, add in Plex & Plexamp. Seems like a network issue
New Linux Plex Server - No Remote Access
Upgrading to Version 1.32.0.6918 removes custom ssl certificates
Plex series agent not working
Plex on Unraid. PLEASE GOD HELP>
Plex Web App won't connect to server following server update - 1.32.0.6950
Plex Employee to Reset Server Certificate? "API rate limit exceeded" error
PMS SSL Uses *.plex.direct Let’s Encrypt SSL certificate instead of custom configured certificate
Unrecognized domain / IP
Plex Custom SSL Certificate Appears Broken
Suddenly no remote access
Custom Domain Certificate Not Used
Some SSL error with custom certificate
Selectively changing directory and file permissions.
PMS 1.31.1 and above monitor your media for file permission changes in addition to media content changes.
This was provided so PMS knows when your media acquisition processes (DVR/other tasks) complete and the media is now ready for PMS to use.
Unfortunately, a number of our users have a “sledgehammer” :hammer: approach where they just change all permissions for all media.
PMS is now sensitive to ALL permission changes (even for media already matched).
This results in the scanner activating.
The solutions here are:
  1. Have your post-processing task apply permissions correctly to the item(s) you’re adding as you add them
  2. Should you need to apply bulk changes, (which should be rarely), below is how to change only those files and directories which don’t match the desired permissions.
The two ‘find’ commands below scan for files whose permissions do not match the mode given and then performs a targeted -exec on that single file or directory to set to the appropriate value.
(Change the permissions below to be appropriate for your usage.)
find /directory-top -type d \! -perm 0755 -exec chmod 755 {} \;
find /directory-top -type f \! -perm 0644 -exec chmod 644 {} \;
Back to top
