There is a schedule now for 4.6
I have referred to Gracenote a request to add 10.1 WJAR-DT (NBC) to the lineup
For 38.1 it appears to be already in the lineup and it does have a schedule - please go to DVR Settings and click on enabled channels link and see if it is matched to the lineup channel
Info: I have created this topic relating to the recent fix for recording reboots of TV Shows
There was a schedule for channel 4.6 Story. But it’s just gone back to “unknown airing.” And still only “unknown airing” for 4.5 Catchy Comedy. The progress was heading the right way but seems to be taking a step back now. ![]()
Hello, just following up to see if Gracenote ever gave an update on this request since it’s been almost 5 months. Thanks!
Please add WHAS 11.9 Dabl to the Louisville, KY lineup.
Thx
I can see a problem - the schedule that we are returning starts on the 31st August. I have referred it back to our ingestion team
I just checked the lineup for zip code 91761 - lineup: Local Broadcast Listings and the channel was added
63.3 KBEHDT3 (KBEH-DT3) Affiliate: Retro Television Network
and there is a schedule
Go through Server DVR Settings and click on the enabled channels link and map DVR channel 63.3 to EPG channel 63.3
This has been referred to Gracenote. I also mentioned that 11.7 HSN and 11.8 QVC which show in rabbiteears.info are not in the lineup
Looking ahead, both 4.5 catchy comedy and 4.6 story show a schedule starting 8/30/2003 at 6pm mt.
Please add the following channels for the Montgomery, Alabama market listed on RabbitEars :
12.6 Oxygen (WSFA)
15.1 Telemundo (WBXM)
15.2 WSFA
15.3 SBN
15.4 Heart
15.5 ShopLC
15.6 HSN
39.1 WETU (DAYSTAR)(HD)
39.2 Daystar ESP (HD)
39.3 Unknown Daystar Channel
48.8 Weather (WIYC)
48.9 Placeholder
48.10 DigiTV
I found some EPG that is no longer accurate if the upstream EPG provider could be informed of these changes. Couple channels that should be added and a couple that have changed.
My local broadcast location is zip code 58501, Bismarck, North Dakota
Channel KFYR 5 added subchannel 5.6 Grit but does not show up in the channel matching yet.
Also under the KNDB subchannels of 26
26.1 is no longer COZI TV, it’s a local news/sports station BEK-TV if that logo could be updated
26.2 is BEK Sports+ West
26.7 is now Jewelry TV (JTV), not Comet
26.11 is now Scripps, not FNX
26.12 is now TWIST, not Jewelry TV
As of 6pm mt this evening (8/30/2003) both 4.5 catchy comedy and 4.6 story have fully populated schedules. Thanks for your help.
Thanks for following up with me. I checked the setting but there’s not an entry for 63.3 RETRO in the EPG channels, so I’m unable to enable it. I’ve attached a screenshot to show what I’m seeing on my end. Not sure what the disconnect is, any suggestion or help you might offer would be appreciated. Thanks again!
It depends on lineup name and zip code
The one I looked up is lineup: Local Broadcast Listings for USA Zip Code 91761
I just checked again and it is there. What lineup and zip code are you using in DVR setup
Missing channels.
Line-up: Local Broadcast Listings, USA, zip code 32571 (Pace, FL), Market Mobile, AL
PMS: 1.32.5.7349
10.6 Oxygen
28.1 Infomercials
28.2 NTD America
28.3 Shop LC
28.4 Religious
28.5 LX
28.6 TeleXitos
48.3 Twist
48.5 DEFY
48.7 Scripps News
53.2 TCT
53.3 Antenna TV
53.4 The Grio
A fix has just been released in Plex Web (hosted) and Plex Desktop that should fix this problem
Plex Web 4.114.2 (hosted - via https://app.plex.tv/desktop)
Plex Web - #424 by rubenamorim
- Fixed a regression that could cause cast images to fail to display in detail pages
Plex Desktop App 1.77.2
The fix for the above should also fix the problem causing the DVR Priority lost images
I have referred the gracenote the following:
- Adding 5.6 Grit from KFYR-TV
- change 26.1 to BEK-TV
- change 26.2 to BEKSP+W
- change 26.7 to Jewelery TV
- change 26.11 to Scripps
- change 26.12 to Twist
