Network 10 HD Australia is missing icons.
Currently residing in Adelaide and both channel 1 and 15 are affected.
This is also happening in Adelaide.
I have been searching the forum for a solution to my problem but have yet to find anything useful.
My issue is that sports programs are altering the time at which other programs air, which causes the other programs to not be recorded properly. I am in the United States and Football is currently causing me these headaches.
For example, the Yellowstone (2018) series has recently been airing from the beginning of the series on Sunday nights. I took this as a great opportunity to record the entire series. However, football is on all day on Sunday and consistently runs over the allotted time on the EPG. So, Plex starts recording an episode at, say, 9pm, but the game went until 9:30pm, so I now have 30 minutes of football and the first 30 minutes of the show.
I attempted to ‘fix’ this issue by using a script to auto-refresh the guide data at 20 and 50 minutes past the hour in hopes that the EPG data would be updated as the games ran long. However, this did not fix the issue as the data does NOT seem to be updated in near real-time as games run long.
I realize I could just set a big pre/post pad on the recordings to ensure that I capture the show. But, then I have to go back and edit everything. There has to be a better way to do this.
So, is there any way to get more updated EPG data natively in Plex, or do I have to switch to using a 3rd party provider?
The Gracenote guide data is missing for the Boston/Providence Market (reference zip code is 02779) for the following Over The Air channels:
Chan# Callsign
4.5 WBZ 4.5
15.3 NBC LX
15.4 Oxygen
24.1 WFXT
46.5 JTV
50.1 WWJE-DT
51.2 COZI
51.3 Oxygen
60.1 WNEU-DT
60.2 Xitos
I can see the problem - I will follow it up, Not sure if it is a gracenote error
Can you get more information concerning the missing channels
43.2 SBN
43.3 Jewelry
43.5 HSN2
43.6 TCN
Callsigns ?
Broadcast by which station ?
Which TV Market ?
I cannot see 43.x in market Boise, Idaho here RabbitEars.Info
I have referred this to Gracenote - they appear to have a logo for the SD channel - channel 10 but not the HD channel which is on vcn’s 1 and 15 in the lineup
I am sorry but overrunning programs cannot be accommodated for - the only option available to use the pre and post pad feature to end recording x minutes after
It is unlikely that the stations provide gracenote with updated schedules to reflect overrunning events as they would not be able to forecast that happening and in any case, gracenote have to ingest these updates and then make that data available to us - which would get picked up in periodic updates and then these would get picked up by the Plex Media Server periodic (daily) or maual EPG refresh
I managed to find matches for these on RabbitEars.Info for the Boston, MA market
4.5 from WBZ-TV : Catchy Comedy
46.5 from WWDP: JTV Jewelry TV
60.1 from WNEU: WNEU-DT Telemundo
60.2 from WNEU: Xitos TeleXitos
I have referred these to Gracenote
For the others i cannot find on rabbitears for Boston
15.3 NBC LX
15.4 Oxygen
24.1 WFXT
50.1 WWJE-DT
51.2 COZI
51.3 Oxygen
Could you give more info and confirming they are for Boston market
ChannelMaster lists them:
Hi sa2000,
Thank you for the reply. Please refer to titantv.com which is more complete. This location is in between Boston, MA and Providence, RI.
Boston, MA OTA market:
15.3 NBC LX
15.4 Oxygen
24.1 WFXT
50.1 WWJE-DT
Providence, RI OTA market:
51.2 COZI
51.3 Oxygen
Hi sa2000 and others on the Plex team,
Can you confirm that Plex uses Gracenote for the Channel Guide in the US?
Gracenote support provided me a process to report guide data problems directly to them from end users. Gracenote support have previously responded and are correcting issues using this process.
Would it make sense to use the direct reporting process and eliminate additional work for the Plex team? OR, Another proposal is that users could use the Gracenote reporting process first and use the Plex process as a fallback if they cannot resolve the issue with Gracenote? If you agree, I can post instructions here.
can you add Retro TV
San Diego
KSDY-LD • 50.3
A local PBS channel has added a reading service for the blind on a sub-channel of the main PBS station. WOSU-D7, channel 34.7
Above is my channel sources. VoiceCorps has a daily program guide here (Although just marking it a VoiceCorps 24x7 would work too)
https://voicecorps.org/programming/schedule/
Country: USA
Postal Code: 43204
Columbus, Ohio Market/Region
Server Version 1.32.6.7557
Thanks for the info. I assumed this was the case. I only asked because I vaguely remember from back in the day when I had cable that the cable company EPG would update in near real-time as events ran long. Was hoping something similar could be implemented.
Pick (UK Freeview) is full of To Be Announced today (2/10/2023) and Friday (6/10/2023)
The channels in my OTA got messed up. Can this be updated?
ZIP: 45201
Connection: OTA
Viewing area: Cincinnati OH, USA
Guide: Cincinnati TV Guide - TV Listings
Linup name: Local Broadcast Listings (74 channels)
Channel 25.2 Cozi TV is showing the same linup as 25.3 This TV. The linup should be different.
Channel 25.8 Quest is missing from the linup.
Thank you.
Some of these have been resolved. There are some national ones that should be easy, but didn’t make it, like Oxygen and Antenna TV.
Missing channels.
Line-up: Local Broadcast Listings, USA, zip code 32571 (Pace, FL), Market Mobile, AL
PMS: 1.32.6.7557
10.6 Oxygen
28.1 Infomercials
28.2 NTD America
28.3 Shop LC
28.4 Religious
28.5 LX
28.6 TeleXitos
53.2 TCT
53.3 Antenna TV
53.4 The Grio
I miss the EPG for one channel (CNBC Europe) in my lineup, see below for the details.
What the actual problem is: Channel mapping is wrong, EPG missing
Channel 324 is CNBC Europe but currently mapped to CNN International; CNBC is missing from the EPG completly
See here for the current channel lineup of the provider:
Lineup name: Quickline Digital TV (Deutschschweiz) (260 channels)
Channel number and channel name: 324, CNBC Europe HD
Country: Switzerland
Postal code: 6300
Region/market: Zug / WWZ
Version of Plex Media Server in use: 1.32.6.7557
Appreciate any help!
John
I am having issues with my local ABC HD station. Channel 784 showing MeTV (KKTQLD2) guide data when it should be showing the ABC station KKTQ.
Your country - USA
Postal code - 69336
Region/market - Bridgeport, NE (Spectrum cable)
Version of Plex Media Server in use - 1.32.6.7557
