They may have changed some numbers around again, or its possible I was mislead by how my vBox scanned in the channels.
I found this link below within the one you provided. It seems to be accurate. Ireland wouldn’t be the most advanced when it comes to trying to find a good source but this one does look accurate
If it is still an issue, please compare what you see in the guide listing on various Plex client apps - eg Web, Desktop app, ios, android - whatever you have available
I am looking into this - can you check if we also need Gracenote to correct the other 20.x channels - They do not appear to correspond to what I am seeing on RabbitEars.Info for Portland, Oregon
Please rescan the tuner channels and then confirm what you are receiving from the tuner for each of 20.1 to 20.7
Sorry I have only just managed to get to your post.
Will need to wait now until this is broadcast again - please try to catch it a few days before the airing is due as I am unable to check it retrospectively
Is what the EPG has for 806 wrong?
It is showing as SECAHD
Anyway - I passed your list on apart from channel 448
I have also mentioned the timezone issue with
859 truTV HD
Is it still wrong
I found the Spectrum channel list here but it does not give channel numbers
Do you have a public web page / pdf link for their channel lineup with numbers? Spectrum Channel Lineup & Channel Guide
Thanks, I’ll keep an eye open for when it’s next on.
Did you see about the issue I reported with the episode numbers for Rick and Morty on Legend (41)?
The episode on Monday 10th October (JuRicksic Mort) is listed as Season 6, Episode 5 when it should be Episode 6. Which is possibly related to this Monday’s Episode (Final DeSmithation) which was actually Episode 6 not having had an episode number and having the date instead.
Thank You - I have asked Gracenote to add 20.6 and 20.7
Note that for Portland, Oregon there is also another set of 20.x channels (KOXI-CD set) - that have been requested for Gracenote to add - Not sure if both sets will be in the end in the lineup for 97003
@ TerrillJarvis - I’m quite surprised that is what you’re seeing KOXI-CD broadcasting. Are you for certain that’s the programming you see tuning into these channels. I just checked these channels on my end on 10/7 and i see different as follows.
20.1 - Jewelry TV (Station removed Azteca America after METV 20.7 was added not sure when)
20.2 - NTD (New Tang Dynasty)
20.3 - Buzzr
20.4 - Telemundo
20.5 - Shop LC
20.6 - LX
20.7 - METV
@sa2000 Rabbitears.info hasn’t updated 20.1 on their end (snapshot below)
On the HDHomerun app, 20.1 still lists Azteca America but has mapped the rest accurately
As you may have noticed the Portland, OR OTA market is strange with the programming changes.
Yours is probably right. I went off of what my HD HomeRun Flex 4K was telling me, which may not be correct. I should have taken the time to actually watch each channel to see what is being broadcast.
I first caught the KOXI-CD inaccuracies when i purchased my HDHomerun Connect 4k. I tuned into the “mystery” channels i seen and noticed different programming than what Silicondust had mapped the channels to. I wish i had a snapshot of that but when i discovered Buzzr it was listed as an INFOMERCIAL channel on the side (slicer) guide.
Perhaps someday (with alot of patience) there will be a perfect, top-notch OTA channel lineup.
