Server Version#: 1.15.5.994
Web Client: 3.95.2
I tried to set up Remote Access by manually specifying public port (left port to default) and since applying this, I am getting the “Looking for servers…” running forever. I cannot seem to find a way to disable Remote Access at this point since the Setting “Remote Access” is not available (not shown) in interface via QNAP or Web access (https://plex.tv).
Does anyone know a way to disable “Remote Access” or get me back to accessing plex server?
Before reading your reply, I tried deleting the Preferences.xml and this helped get me beyond the problem “Looking for servers…”. I now can see my libraries on a server. It seemed that in deleting the Preferences.xml, I had to recreate the Library (but it seems to have same structure I had before). I now have an issue with Claiming Server… when I click on button to claim server it quickly goes back to Claim Server again.
To answer your question. With the change I made I am able to bring up Plex using http://<IP_OF_QNAP>:32400/web. The first two blocks are 10.0.x.y.
I copied claimpms.sh to QNAP and ran it with 127.0.0.1 IP. The result is an: ERROR
We failed to authenticate towards plex.tv
Please check username and password, as well a network access
I believe I am entering in correct username and password, so not sure what is wrong. I will have to check tomorrow at this point. Is there a way to check network access from Putty? I could certainly ping 127.0.0.1.
When I ping ping-test.net I receive: Network is unreachable.
I am not familiar with putty so not sure if I need to set something up specifically to get network access. I am using QNAP IP address as my host for putty.
I changed QNAP to static ip and have set default gateway to my router. I do not see any change in “Network is unreachable”. Do you have any other suggestions?
I tried the values out of command ipconfig for QNAP and am having no luck. Is it possible to run the claimpms via windows rather than on QNAP itself? Just an idea.
