Louis Theroux documentaries not found...I tried everything!?
These shows don’t show up AT ALL in Plex. So I can’t even try to manually rename, add a description, etc… The scanner just isn’t picking them up:
Louis Theroux - The Most Hated Family in America (2007).mp4
Louis Theroux - America’s Most Hated Family in Crisis (2011).mp4
Louis Theroux - Surviving America’s Most Hated Family (2019).mkv
And this is how they show up at TheTVDB:
Plex - Louis Theroux naming issue
I tried using both the Plex TV Series & Plex Movies scanners to no avail.
So…what am I doing wrong?
Thanks in advance! :slightly_smiling_face: :+1:
Plex uses IMDB & TMDB for movie information, not TVDB.
  • They are movies. Place them in a movie library and use the default Plex Movie scanner & agent.
  • Do not replace the colon, or any other illegal character, with a dash. Just leave it out.
  • If a MP4 file has incorrect embedded metadata it can throw off Plex matching. Either correct the metadata or tell Plex to ignore it. Edit the Library → Advanced → deselect Prefer Local Metadata.
  • Plex Dance each movie after renaming and reorganizing.
This matches immediately on my server:
/movies <-- folder added to movie library
  /Louis Theroux The Most Hated Family in America (2007)
    /Louis Theroux The Most Hated Family in America (2007).mkv
Thx for your reply!
I’ll give that a try but a quick question…how do you determine if something is TV or movie?
Because the Louis Theroux certainly were never released in a theater, they are produced and were aired on the BBC and they are 60 min long so…it seems that to most people this would be a TV show?
I understand this is strictly what Plex views as movie or TV but I just want to know so I can get it right the first time in the future because I have many more with the same problem.
Cheers,
Go by how they are listed at IMDB/TMDB/TVDB. Also at watch.plex.tv.
It can be confusing at times. There are Louis Theroux TV shows and movies. You’ll have to check each item individually. Note that a TV movie goes in a movie library, even if it aired on TV.
There are sometimes conflicts between IMDB/TMDB/TVDB, and sometimes one of the sites is just wrong. Either can mess up Plex correctly matching and pulling metadata. When that happens, post in the forum with the details, so a Plex employee can take corrective action. You can also create a personal account at TMDB & TVDB and edit most listings. If the site admins approve the changes, Plex will pick them up in 48 - 72 hours.
You can use Plex’s Collections capability to have the shows and movies listed together. Place them in a collection with the same name.
Ah yes, now I see it, I had looked everywhere on the IMDB page and it’s right there to the left of the title :wink:
And after doing what you wrote above, the Louis Theroux were in fact recognized!
Thx!
