Match problem
Server Version#: 1.16.5.1554
Player Version#: 4.1.1
i have weird match problem which occours only on TV SHOWS
no matter what i did it keep happening - the cover is major lazer lean on song.
things I tried:
read your artice of fix matching
update server to the latest version
empty database
reload files
manual match ( still get this cover)
delete list and recreate it.
by the way i dont have lean on song on this directory or even on the parent dir
please help.
Hi Otto,
I tried everything you suggested and all still the same.
something I forgot to mention earlier… the movies library is the same as the TV shows library… but in the movies library i dont have this problem…
What do you mean by that?
It cannot be the same, since a movie library requires a different naming schema and folder organisation than a tv show library.
I configured 2 different and separated libraries for TV Shows and Movies.
both of them configured with the same directory.
Very bad idea. Don’t.
Ok,
I will try to separate them and try again.
will update soon.
And to add as to why this is.
It’s because the naming convention & organization of the two types of libraries are completely different. Movies have one set of naming convention and shows follow a different set of rules.
Movies
https://support.plex.tv/articles/naming-and-organizing-your-movie-media-files/
Shows
