Server Version#: 1.41.3.9314-a0bfb8370-x86_64_DSM7
Player Version#: N/A
Synology DS-918+
DSM: DSM 7.1.1-42962 Update 7
I got caught in the issue mentioned in previous posts where Package Center was blank and my media was unreachable.
I applied the following fix provided in the Synology forum which made Plex accessible again via Package Manage.
I’m also able to reach it via https://ds918_fqdn:32400/web/index.html#!/
This is where it all goes wonky.
When I go to ‘Settings’, there is no ‘Library’ settings at all. I’ve got headings for my account and for ‘Plex Web’ but nothing else.
When I’m at the home page, there’s a pinned heading “+ Your Media Files” but when I click on this is tells me to download Plex Media Server.
I’ve already verified permissions on the PlexMediaServer folder, Plex folder, Music, Video and Photos folders. All looks good. I even expanded some of these from being Read/Write to full Admin just in case.
I’ve uninstalled and reinstalled. I’ve re-started the app. The only thing i haven’t done is a full uninstall and reinstall; meaning blown away the PlexMediaServer folder. I’d like to avoid this if possible but whatever needs doing.
sed -i ‘s/SYNO.SDS.htmlEncode/Ext.util.Format.htmlEncode/g’ /usr/syno/synoman/webman/modules/PkgManApp/PkgManApp.js
When I first reinstalled it I saw the token options. I did a little googling trying to figure out if I needed a token or not. In the past I don’t remember having to do this. Just login with my account and that is it.
So, the token ties the server to my account. I’ll remember this in the future.
Curious, what was the reasoning behind implementing using a token for the server?
When the credentials get confused / messed up., that (re)install option clears out the current values from Preferences.xml and writes fresh (using the claim token you give it)
