Server Version#: 1.18.0.1944
Player Version#: 4.8.4
The new TV show 2019’s “Bob (Hearts) Abishola” has its metadata incorrectly matched to the 1992’s “The Bob Newhart Show”. Please correct.
Thank you.
Lifetime PLEX Pass member
Thank you.
Name the show as per TheTVDb.com (without brackets around the “Hearts”):
TV Shows
Bob Hearts Abishola
Season 01
Bob Hearts Abishola - s01e01.ext
Bob Hearts Abishola - s01e02.ext
That should do the trick ![]()
Edit:
You can either use Fix Match from within the Plex Web app or apply the correct file/folder names in combination with the Plex Dance (move the show’s folder out of Plex scope, scan the library for updates, empty trash, clean bundles, fix names and return the folder to the Plex scope, scan the library for updates again…). The “dancing” part will take longer but could be helpful if you have to / want to restart your server at some point from scratch ![]()
