My cloud home will not connect to plex no matter what
I try I have looked though forums and nothing has
Worked my cloud is on and working but will not connect
Just keeps trying to connect with no joy if anyone
Can please help me
Thank you
Mike
Can please help me
Thank you
Mike
You’ll need to be a little bit more specific.
What do you mean by “the WD MyCloud Home will not connect to Plex”?
Sorry I mean i has it all logged in and working Plex was running fine and then when I went to log into Plex today it just says my cloud server is unavailable and keeps trying to connect
Mike
Can you access the Plex Media Server…
Yes that’s worked and has sent me back to Plex main screen and now there is 2 my cloud servers one is populating my content back in the other is still saying not able to reach is this normal?
So sorry for the dumb questions
Mike
This might have happened if you at some point deleted the app and installed a new one. If that’s the case you should be able to remove the „not available“ one by deleting it from the list of authorized devices (be careful not to delete the actual server)
I seem to have a similar problem, at some point (I’m not sure when) my Plex add on to my My Cloud home has disabled. I’ve re-enabled it through the My Cloud Home UI, I can get as far as the configure link but the link does not work, Plex does not seem to be connecting to my My Cloud Home at all.
Considering you’re trying to revive/hijack this old thread… are you looking for assistance?
If so… let’s get in some specifics about your issue. Let’s start with some basics such as:
I would love some assistance, thank you very much.
Plex version 1.18.1.2350.
http://app.plex.tv/desktop and IP address links both workfine,
I’m running firefox but it’s the same through the Windows app, LG TV app and Android App.
I’ve got a PiHole running but it’s the same when I disable it. I’m just trying the PiHole off for longer in case it’s a DNS issue but there doesn’t seem to be any problem connecting.
so you basically just get a wrong URL when clicking the configure button for Plex in the QNAP package center?
Yes, I think so
I’m assuming I need that link to work before Plex will connect to my My Cloud Home. This has all worked fine previous but just seems to have stopped
just bookmark http://app.plex.tv/desktop – there’s no need to open the Plex web app from within your WD MyCloud.
I can log onto Plex fine, there’s just no evidence of my My Cloud or anything in the Plex folder there. I’d followed the instructions and realised for some reason it was no longer enabled, I’ve enabled it and it’s made no difference.
Apologies… I was confused when you wrote that you can access Plex Web and assumed this included you being able to see the server running on your WD MyCloud.
Do you get a different result when opening Plex through the MyCloud’s IP address (http://[mycloud ip address]:32400/web)? If the server is running this should provide you with the locally installed version of Plex Web. If it’s there and you still cannot manage the server from there… something’s fishy.
Thanks just tried that unfortunately that doesn’t work, i can log onto Plex through apps etc but the IP:32400/web doesn’t seem to work.
What do you mean by that?
I can open the Plex app on my phone and there’s content there from Plex but I can’t access any of the content from My Cloud Plex folder. So I have access to Plex but it looks like Plex isn’t talking to my My Cloud Home.
Got it. Do you get any error message when you try to open Plex through your browser using the WD MyCloud IP address?
Just that it can’t connect, the browser’s normal error:
Problem loading page
