in plex i have 5708 folders in folder view, but in regular view it shows 5706. and on my NAS in the movie folder I have 5708 movies.
how can I figure out what movie is missing in my plex library?
try filtering on duplicates.
I have done that and even tried the unmatched filter as well, but I dont have any duplicates or unmatched items.
Can you sort your library by anything but By Title?
This will show the actual # of movies (e.g. in case if your libraries has some collections, hiding their items in the regular view).
Another option could be some titles matching the movie spread across multiple files naming schema (e.g. My Movie - Part1.ext and My Movie - Part2.ext being treated as a single item My Movie → no duplicates involved in this case).
I sorted my library by year instead of by title and it shows the same amount of movies.
how do I see if movies have been spread across multiple files?
then it may be a part 1 and 2 it thought was first and second halves of one movie. Like Harry Potter Part 1, Harry Potter Part 2 if you have file names that end with those then i would do get info on those.
There is Web tools as well which may help with this general sort of thing WebTools-NG
ifi upload my logs would someone be able to tell me if. there is anything wrong?
It’ll be easier to check out the WebTools app linked above.
Scanning your logs for 2 missing items in a forest of almost 6k items won’t be a simple task ![]()
ok I will tr the web tools. how do I download it? I am on the page, but I dont see anywhere to download for my Mac…
Assets section of the latest releaseok I got it up and running, im not sure what I need to do now.
ok I got it to export my movies to a cvs file.
They want you to export a CSV file from your movie library in the level All
Click here: Export · WebTools-NG/WebTools-NG Wiki · GitHub
After it’s done, compare the field named Part File Path with the folders in your file system
so it appears that two of the movies that were not in my library were
ghostbusters afterlife and 47 meters down.
on my synology, how can I make sure all movies and subfolders all have the same permissions? I recently had those 2 movies upgraded in radarr, I think it might be radarr that is changing the permissions on the folders.
