No metadata with Iocage Jail on Freenas
Server Version#: FreeNAS 11.2Beta3
Player Version#: 1.13.2.5154
I have already posted to the FreeNas Forum: https://forums.freenas.org/index.php?threads/plex-no-metadata-11-2beta3-iocage-jail.69907/
Not sure if the problem is due to Plex, FreeNAS, or my local network setup.
I have set up Plex within a new iocage jail (after the warden based plugin stopped working).
The plex server is accessible, and playback works fine. However no metadata appears.
I have tried many other solutions including the steps indicated here: https://forums.freenas.org/index.php?threads/iocage-plex-metadata-and-transcoding-issue.60628/
About my setup:
Home network is on the 192.168.0.0/20 subnet (192.168.0.1 - 192.168.15.254)
Cable Modem - Bridge Mode
192.168.0.1 - Primary router connected to cable modem via Cat5
192.168.0.2 - Secondary router connected via WDS Bridge to first router, connected to FreeNAS box and desktop computer via Cat5
Both routers are TP-Link Archer C7, with forwarding/virtual server (Edit: NAT only on Primary Router):
https://forums.freenas.org/index.php?attachments/upload_2018-9-13_10-21-27-png.25674/
192.168.10.1 - FreeNAS IP Address
192.168.10.5 - Plex Iocage IP Address, set via DHCP reservation:
https://forums.freenas.org/index.php?attachments/upload_2018-9-13_10-22-18-png.25675/
Here is the contents of “iocage get all plex_jail”:
root@freenas:~ # iocage list
| JID |   NAME    | STATE |   RELEASE    | IP4  |
| 2   | plex_jail | up    | 11.2-RELEASE | DHCP |
root@freenas:~ # iocage get all plex_jail
CONFIG_VERSION:11
allow_chflags:0
allow_mount:0
allow_mount_devfs:0
allow_mount_nullfs:0
allow_mount_procfs:0
allow_mount_tmpfs:0
allow_mount_zfs:0
allow_quotas:0
allow_raw_sockets:1
allow_set_hostname:1
allow_socket_af:0
allow_sysvipc:0
available:readonly
basejail:no
boot:on
bpf:yes
children_max:0
cloned_release:11.2-RELEASE
comment:none
compression:lz4
compressratio:readonly
coredumpsize:off
count:1
cpuset:off
cputime:off
datasize:off
dedup:off
defaultrouter:192.168.0.2
defaultrouter6:none
depends:none
devfs_ruleset:4
dhcp:on
enforce_statfs:2
exec_clean:1
exec_fib:0
exec_jail_user:root
exec_poststart:/usr/bin/true
exec_poststop:/usr/bin/true
exec_prestart:/usr/bin/true
exec_prestop:/usr/bin/true
exec_start:/bin/sh /etc/rc
exec_stop:/bin/sh /etc/rc.shutdown
exec_system_jail_user:0
exec_system_user:root
exec_timeout:60
host_domainname:none
host_hostname:plex_jail
host_hostuuid:plex_jail
host_time:yes
hostid:3b4eecf0-7778-11e7-9261-d05099c26ec6
hostid_strict_check:off
interfaces:vnet0:bridge0
ip4:new
ip4_addr:vnet0|192.168.10.5
ip4_saddrsel:1
ip6:new
ip6_addr:none
ip6_saddrsel:1
jail_zfs:off
jail_zfs_dataset:iocage/jails/plex_jail/data
jail_zfs_mountpoint:none
last_started:2018-09-13 05:58:08
login_flags:-f root
mac_prefix:02ff60
maxproc:off
memorylocked:off
memoryuse:off
mount_devfs:1
mount_fdescfs:1
mount_linprocfs:0
mount_procfs:0
mountpoint:readonly
msgqqueued:off
msgqsize:off
nmsgq:off
notes:none
nsemop:off
nshm:off
nthr:off
openfiles:off
origin:readonly
owner:root
pcpu:off
priority:99
pseudoterminals:off
quota:none
release:11.2-RELEASE-p1
reservation:none
resolver:/etc/resolv.conf
rlimits:off
securelevel:2
shmsize:off
stacksize:off
state:up
stop_timeout:30
swapuse:off
sync_state:none
sync_target:none
sync_tgt_zpool:none
sysvmsg:new
sysvsem:new
sysvshm:new
template:no
type:jail
used:readonly
vmemoryuse:off
vnet:on
vnet0_mac:02ff602fd575,02ff602fd576
vnet1_mac:none
vnet2_mac:none
vnet3_mac:none
vnet_interfaces:none
wallclock:off
And the results of running ifconfig from within the jail
root@plex_jail:~ # ifconfig
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
        options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
        inet 127.0.0.1 netmask 0xff000000
        nd6 options=21<PERFORMNUD,AUTO_LINKLOCAL>
        groups: lo
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:ff:60:2f:d5:76
        hwaddr 02:5f:d0:00:07:0b
        inet 192.168.10.5 netmask 0xfffff000 broadcast 192.168.15.255
        nd6 options=1<PERFORMNUD>
        media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>)
        status: active
        groups: epair
I have uploaded all of the logs from Plex here: https://drive.google.com/open?id=1I9RCLVPKe1_qCAdMg9vmm5gfVCgXh4bJ
Any help would be much appreciated. I have been tearing my hair out for 3 days trying to get this to work.
This sounds similar to the problem I’m having. Cover art for movies and TV shows is not showing up, and metadata isn’t being entered.
For those of you who might be having the same problem I was having (metadata and cover art not downloading), here is my solution:
I re-created my jail and set it up to use the “VNET” option instead of the physical interface. I had some trouble doing this at first, but I got it figured out through some trial and error. (Important note, if using VNET, be sure to set the default route). Next, I set “Allow Raw Sockets” to “True”.
I don’t know which of these two things fixed the metadata and cover art, but it’s working now!
Much appreciated. I was having the same problem and this corrected it.
What did you end up setting the default route to?
• none
• same as < ipv4 address >
• same as global < default route >
• < unique ip address >
• other?
Thus:
< router ip >
