Paw Patrol Series Meta Data not correct
Server Version#: 4.108.0 - Docker
Player Version#: Web
Dear Support,
the 2nd Season has a wrong cronological list of the Episodes:
https://thetvdb.com/series/paw-patrol/seasons/official/2
Is the correct list, which plex doesn’t seem to use. How can I change that?
KR
Rok
Thank you!
KR
Rok
Go to the top level of this show. (easiest by clicking on its title)
Edit it.
Go to the Advanced tab.
Set “Episode ordering” to “TheTVDB”
If you exclusively use the episode ordering from TheTVDB for all your shows, you can do the same in the properties of the library.
Thank you for your reply! I’ve changed the DB to IMDB but I still have the same issue with the episodes. What should I do to make them work?
This is not possible for TV shows in Plex.
Are you trying to put a tv show into a “movies”-type of library?
Sorry my Bad - I’ve chosen the Movie DB which I though it is the IMDB list. Would it be possible to change the Airing for meta data? The Pawpatrol was aired differently in Canada than in the States and my version is the US on. Would it be possible?
What means TVDB (DVD) or TVDB (Absolute).
KR
Rok
Plex uses one of these episode orderings. And only these:
  • TheTVDB (aired)
  • TheTVDB (absolute)
  • TheTVDB (DVD)
  • TheMovieDB
Look up your show on either TheTVDB.com or TheMovieDB.org.
If none of the episode orderings on these sites match your files, you will unfortunately not be able to sort them that way in Plex.
they have a “Aired” list, but the list has 2 options:
Aired and US Aired and my version is US aired.
KR
Rok
US Aired is unfortunately not supported.
Understood, is there an Option to support it in the future?
KR
Rok
There is an open feature request: Support Alternate Order / Flexible Seasons (TVDB) and Episode Groups (TMDB)
