Phone stays on after playing video until battery is completely drained
I should have said, autoplay is turned off for me too when this happens
Same problem with the all on Google TV with Chromecast.
See: BUG: Next episode's audio starts playing when watched episode ends on Chrome Cast with Google TV
Same problem as Gavin-Ashford on Nebula Capsule Max – plays one more episode in background then stops; at least that’s what it seems.
I think this is resolved for me - I went into the settings and enabled and then disabled the ‘Auto play’ setting yesterday and it doesn’t seem to happen anymore.
Perhaps there was an behinds the scenes update related to that setting at some point and the original selection wasn’t correctly migrated and has been causing the issue.
@m1ndstorm perhaps try the same and see if that helps things for you too.
I’m currently on Plex Android v8.13.1.23036
@Gavin-Ashford Indeed, it appears to be fixed. Not sure if it was the auto play switch or the version bump (also on 23036) but many thanks for the tip!
