@afbergner said:
I’m getting shaka3016 errors when playing back certain FLAC files in the Edge browser on Windows 10 (1703), which worked fine until I updated to version 1.8.4.4249 of the Plexmediaserver plugin for FreeNAS earlier today. Tried the same FLAC files in Chrome and they’re playing fine.
Figure I would throw this out there… Too tired right now to bother with logs, but I ran into this a little bit ago…
Server is running on Win7, playback is in Win10 using Chrome.
Media has subs in it, plex is defaulting to not using the subtitle file which gives an error instantly at start, enabling the subtitle allows proper playback.
Here’s the “Media Info” plex provides with out me poking deeper.
Media
Video Resolution 480p
Duration 25:10
Bitrate 1652 kbps
Width 704
Height 480
Aspect Ratio 1.33
Container MKV
Video Frame Rate 24p
Video Profile high
Part
Duration 25:10
File Noein S01E19.mkv
Size 297.32 MB
Container MKV
Indexes sd
Video Profile high
Codec H264
Bitrate 1204 kbps
Anamorphic 1
Bit Depth 8
Chroma Subsampling 4:2:0
Frame Rate 23.976 fps
Height 480
Level 5.1
Pixel Aspect Ratio 229:189
Profile high
Ref Frames 16
Scan Type progressive
Title [KAA] Noein - 19
Width 704
Codec AC3
Channels 5.1
Bitrate 448 kbps
Language English
Audio Channel Layout 5.1(side)
Sampling Rate 48000 Hz
Title Japanese Audio (2ch AAC)
Codec ASS
Language English
Title English Subs (ASS)
@blacklock said:
I can’t even play several videos with subtitles. The second I choose to use an external .SRT file for subtitles, I get the following:
An error occurred trying to play “Episode 1”.
shaka3015 (Media)
If I then remove subtitles, it starts playing again. This happens every single time on different videos.
It may be a transcoder crash. There is an issue in progress to do with transcoder crashing with some subtitles. As mentioned earlier in this thread - a server log would show the underlying issue. If it is a transcoder crash then a sample set of files (5 minute) giving the transcoder crash could be nice to have and I can add it to the existing issue that is currently open
I’m having the same problem with the latest PlexPass Media Server on Synology – using Safari and Vivaldi. Note that Vivaldi does show the shaka3015 error, followed by some endless spinning icon, but Safari just shows the endless spinning icon.
Here are the logs just after trying to play the same video a couple times in both browsers.
I also have this Problem (shaka3015, shaka3016).
Plex Server (Version 1.9.1.4272 ) is installed on a Windows 10 Machine and my files are on a Synology NAS.
My Web App is Version 3.20.5. So everything should be up to date.
I have this error only on one series, but on every episode right from the start.
the log says “A critical Shaka error occurred: 3015 (Medien); the player cannot recover”
and also “A critical Shaka error occurred: 3016 (Medien); the player cannot recover”
Thanks for the server log. The logs shows transcoder errors reporting incorrect duration values
eg for safari
Sep 23, 2017 21:30:01.794 [0x7f0509d11700] ERROR - [Transcoder] [mp4 @ 0x30a5a60] Application provided duration: -64 / timestamp: 4371288 is out of range for mov/mp4 format
and similar for vivalidi
Sep 23, 2017 21:31:29.255 [0x7f0514223700] ERROR - [Transcoder] [mp4 @ 0x31c6a60] Application provided duration: -64 / timestamp: 957336 is out of range for mov/mp4 format
The file that was being played '/volume1/Downloads/Series/The Americans (2013)/Season 1/The.Americans.2013.S01E01.1080p.BluRay.x264-BiA.mkv'
Does the file play ok with other players?
If it does, will need a short clip giving the problem
Use mkvtoolnix to prepare a 5 minute clip and add it to a test library and if it causes same problem, get media info xml and logs with trying both safari and Vivaldi and logs as before and upload sample on dropbox etc and send me a link to it
I do not really know what to do here, but I turned on verbose logging and then downloaded the log zip. PMS was working perfectly fine. i updated to latest and I cannot play ANY videos, no matter the format. I have downloaded numerous files, movies, episodes, whatever and tested so many. They give me the error shortly after hitting play and will not play at all. Also, then after that the Shaka3015 error pops up at random. Here are logs: https://drive.google.com/file/d/0Bw-ARc6DtAVJcHBPOGE0TDQybjQ/view?usp=sharing
Also, I already tried all suggestions in this thread and elsewhere, nothing works to get them to play. Major bug if ya ask me, I cannot watch anything, lol.
I can see the server saying the client (Plex web) is reporting an error - e.g. here
Sep 24, 2017 19:18:47.569 [0x7f16c0bff700] DEBUG - Client [c5c7tgcpt5gujwxqt2rifhbu] reporting timeline state error, progress of 0/6605000ms for guid=, ratingKey=2 url=, key=/library/metadata/2, containerKey=, metadataId=2
What time was the error ? do you have any screenshots with the time showing.
I cannot see any server errors
Does the error arise on different browsers ?
Could you see if the error arises with a sample file ?
If problem persists, could you see if the error is displayed for short clips - eg produce 5 min video from
‘/home/aaron/Plex Media/Videos/The.Mummy.2017.1080p.BluRay.x264-[YTS.AG].mp4’ and if it happens on th short clip then please could you make it available together with the logs
OK, so I already tried to analyze, no difference. It happens in multiple browsers and it also happens when I pull Plex up on my Roku, it will not play there either. I am not sure what time it was, I would imagine night time. I cannot play a single file. I will try to play a small 5 minute file and get the logs. This is kind of ridiculous, I mean not being able to play a single thing, lol. It was working fine.
For some odd reason, now all my files are playing… All I did was delete the videos and re-add them but I had already tried that in the past. Oh well, good for now I guess, I will be back if other issues arise./
I have the same problem since several week with some videos. I think the problem is related to AC3 playback. I converted the file with HandBrank (preset “Fast 720p30” so with AAC) now the video play correctly with plex.
@chutzler@thfn.org said: @sa2000 Here ya go. The shortened video clip results in the same error being generated as the original (shaka3015 (media)). I’m attaching the logs from the attempt to watch the short one to this message, as well as the screenshot showing the time (the filename for the screenshot even has the time in it this time, as my mac recorded it).
Also note, I think one of my other users was attempting to play something while I performed this stuff, so if you see something accessed other than this file in the logs, it was that user.
Thank you for the sample and logs. I have not been able to reproduce the error on my server and I used 1.8.4.4249 as well and tried both hosted and bundled Plex Web 3.20.5 and chrome 60.0. Could be specific to Mac - my tests were on Windows. In all cases playback was successful. I had one buffering at 10 seconds in one of the tests but recovered after that.
I will pass the link to the clip and logs to the web team
Sorry to have taken so long to come back. Investigation identified the issue being in Direct Streaming in this case, The team are looking into detecting the problem and switching to transcoding if Direct Streaming fails.
I am afraid, in the interim the only way round is to disable Direct Streaming in the web app but that would mean media getting transcoded and not just the specific ones that needed it
The Direct Stream setting is now within the advanced Debug web app settings page
Been using Plex for many many years as a paid subscriber but no more. This error has made it unusable. I am not re-adding my library to fix it. I have 14tb of tv and movies.
I use chrome to access my library and now even if I manage to get a file to play the next one in a series wont. I hate the new overlay as I always have to minimise it to restart the file. What have you done? You have ruined Plex.
So any suggestions for an alternative as I dont see them putting it back as it was I use my plex whilst I do other things so dont need this feature.
I have seen more of the turning yellow circle in the last two days as things refuse to play than i have done in the last 5 years. Congrats you have lost a customer. I dont need to give you a log give me back what I pay for.
