Server Version#: 1.18.7.2457
Player Version#:7.29.2.16071 (Android Mobile and TV)
This has been happening since this version of the app got installed on my Sony Android and and my Samsung S9+
Rebooted the server ofcourse and reinstalled the client apps but still happens.
Also have Plex for Kodi installed on the TV and that works just fine so currently looks like this client version and servers version appear to have some kind of issue.
Had issues with 7.29.2 myself… I went back to 7.27.1 and that worked…
since Ive used the beta updates, found the only one I didn’t have major issues with so far was 7.30.0.16150 There is a later release but I haven’t had time to load and test it.
Same thing here, Bravia X900F and Plex 7.29.2. The video freezes and has to be restarted at about the 17 minute mark every time. This didn’t happen on 7.28. Between this and the problem with the new player completely breaking playback it is amazing anyone is able to use Plex on Android at all.
Was able to get 7.28.x for the phone and it works as expected.
While it’s doable for the TV, its a hassle installing APK’s on that TV without a proper file explorer app and they are totally ■■■■■with remote control navigation.
So just gonna use Plex for Kodi until Plex devs fix it (if ever).
It looks like its an Android Mobile/TV app issue as i had previously rolled back server and still only had issues with Android clients. Kodi and the browser WebApp worked fine.
Just posting here, as I am having same issue. Didn’t notice it till I was able to watch on my other streaming devices fine without issues (eg. Roku).
The easiest way to side load a device I have found is with a windows laptop.
The laptop has to be on the same network segment. (first 3 octets are identical 192.168.5.x)
laptop setup…
Down load and install a program called ADB, it acts like a server connector
This only needs to be done the first time…
You need to be able to run a command window as administrator. (right click run as administrator)
And of course you need to download the correct APK that you need.
I am also having the same issue. I did noticed it affecting all my android devices (fire stick, fire tv, android TV) and 1 Samsung TV. At first i thought it was internet related as i did get a new router back in Dec. this issue started about 2 weeks.
I tried disabled 5G, restricting devices to 2.4gz and vice versa, new router, but in the end its not the router. All streaming services (youtube, netflix, Showtime Anywhere, HBO Go) has no issues on all my devices. I just upgraded to Version 1.18.9.2578 and problem continues.
Since starting this thread the server and android app has been updated twice.
This was resolved for me until the very latest version. It appears to have returned but this time, this build, only appears to be affecting the TV (not seen it happen on the mobile so far).
Seriously disappointed with the testing quality (if it even exists). As this recurrance no longer even tracks the progress of the video that has been watched which means you restart from the start. Atleast the previous bug “performed” better.
I’m new to Plex and am having this issue with DVB playback, it’s not the hdhomerun as it works in other apps. I also just wasted £100 upgrading my network thinking it might be that! Makes the TV unwatchable! Client is a 2019 Nvidia shield.
