gregeeh
November 16, 2025, 9:13pm
1
Server Version#:1.43.0.10231
Hi all,
I have a remote PMS and watch Plex on my Sony TV (Google TV) and quite often it will not start Plex. The app will start and you see the menu on the left and a rotating circle. Clearing the cache, forcing the app to stop or restarting the TV does not help. Clearing the app data, and therefore logging back in, is the only fix.
When the connection issue is happening I can connect to PMS via my phone or tablet just fine.
This happen last night 16th Nov 8:03AM UTC.
Logs attached.
Any ideas appreciated.
Plex Media Server Logs_2025-11-16_19-09-43.zip (2.0 MB)
ChuckPa
November 17, 2025, 1:59am
2
Thank you for the logs.
Nov 16, 2025 18:26:38.000 [140217889131320] ERROR - [Req#18d/Transcode/349857fe-fd7c-4fe7-b125-02635095052c/113984b0-8b7f-4120-9eac-0ff6c5501b07] [eac3_eae @ 0x7fe1e9dc7700] EAE timeout! EAE not running, or wrong folder? Could not read ‘/run/plex-temp/pms-f0a496d4-a0a5-46aa-bb81-3c204069afd1/EasyAudioEncoder/Convert to WAV (to 8ch or less)/349857fe-fd7c-4fe7-b125-02635095052c_362-0-0.wav’
Nov 16, 2025 18:26:38.001 [140217889131320] ERROR - [Req#20c/Transcode/349857fe-fd7c-4fe7-b125-02635095052c/113984b0-8b7f-4120-9eac-0ff6c5501b07] [eac3_eae @ 0x7fe1e9dc7700] error reading output: -5 (I/O error)
Nov 16, 2025 18:26:38.002 [140217889131320] ERROR - [Req#20d/Transcode/349857fe-fd7c-4fe7-b125-02635095052c/113984b0-8b7f-4120-9eac-0ff6c5501b07] [aist#0:1/eac3 @ 0x7fe1e9da2680] Error submitting packet to decoder: I/O error
Notice the EAE (Dolby audio transcoder) is getting an I/O error
Is your transcoder temp on a network share / folder ?
Can you check the permissions to the transcoder temp directory to confirm the plex user (plex b y default) has write permission ?
I ask because you are not overflowing the Notify table ( notify will work )
gregeeh
November 17, 2025, 2:42am
3
@ChuckPa - No not on a network share. Permissions are correct too.
Don’t understand what this means, sorry.
Also the timestamp in the log you have shown is not when the problem occurred.
Thanks,
Greg
EDIT: Permissions were NOT correct, have now changed them. Would this have been the cause of my issue?
ChuckPa
November 22, 2025, 4:58am
5
@gregeeh
Sorry for the delay.
I am concerned about the container’s and LAN’s network config.
You have it configured in bridge mode (?) eth0 (172.17.0.12) (02-42-AC-11-00-0C) (loopback: 0)
Is your LAN IP 192.9.181.x ?
If so, that’s not a valid RFC-1918 LAN address and it’s conflicting with Oracle Corporataion
NetRange: 192.9.0.0 - 192.9.255.255
CIDR: 192.9.0.0/16
NetName: ORACLE-BRM1
NetHandle: NET-192-9-0-0-1
Parent: NET192 (NET-192-0-0-0-0)
NetType: Direct Allocation
OriginAS:
Organization: Oracle Corporation (ORACLE-4)
RegDate: 1983-10-17
Updated: 2016-10-10
Ref: https://rdap.arin.net/registry/ip/192.9.0.0
gregeeh
November 22, 2025, 5:10am
6
Sorry @ChuckPa I should have mentioned that this is a hosted PMS and I have no control over how it is installed.
Greg
ChuckPa
November 22, 2025, 5:50am
7
Thank you. That’s important info.
What’s the Distro they gave you to run on?
gregeeh
November 22, 2025, 5:52am
8
Linux version 5.10.0-33-amd64 (debian-kernel@lists.debian.org ) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 SMP Debian 5.10.226-1 (2024-10-03)
ChuckPa
November 22, 2025, 5:53am
9
what does cat /etc/os-release show ?
Debian 10 ?
gregeeh
November 22, 2025, 5:54am
10
PRETTY_NAME=“Debian GNU/Linux 11 (bullseye)”
NAME=“Debian GNU/Linux”
VERSION_ID=“11”
VERSION=“11 (bullseye)”
VERSION_CODENAME=bullseye
ID=debian
HOME_URL=“https://www.debian.org/”
SUPPORT_URL=“https://www.debian.org/support”
BUG_REPORT_URL=“https://bugs.debian.org/”
ChuckPa
11
How skilled are you (command line) and would you consider making some changes to make your life easier ?
gregeeh
November 22, 2025, 5:56am
12
CLI should be no issue. However I don’t have sudo access which might be an issue. Really interested in solving this issue at the moment.
ChuckPa
November 22, 2025, 5:58am
13
Fair enough.
Have you considered using HOST networking ?
I suggest this because they control the network stack.
You creating a bridged adapter in the container, when you don’t have sudo, is going to make this very difficult / possibly not possible.
gregeeh
November 22, 2025, 6:02am
14
I’m sorry but I have no way of changing anything to do with the installation of Plex. I was hoping the logs and the time I provided would help determine what is causing this issue and why deleting the client data and logging back in made the client connect correctly.
ChuckPa
15
They installed the docker container for you and gave it this configuration?
ChuckPa
November 22, 2025, 6:04am
17
I am VERY sorry but if your hands are completely tied then all you can do is ask them to make the change because, it seems, only they can change the container’s configuration.
ChuckPa
November 22, 2025, 6:05am
19
Change the network from bridged to host.
Who is the provider (name please) so I can go research it before you waste any time?
