Plex fails to start after Synology DSM 6.2-23739 Update 2
PMS 1.13.2.5154 32 bit for DS214play DSM 6.2 only.
https://drive.google.com/open?id=10EoPnrOuPz9yR0lXKUvtl8oJrARE0w1F
Can’t be any slower than my download speeds, Chuck. I have been trying to download the latest update for my Xbox and its been 5 hours so far for a 3GB update!! Logging in to GD now to pull the file. Fingers crossed…
Hopefully downloading and installing 100 MB isn’t so bad.
Be also advised, it will need codecs again. This will increase the start time for the first time only you use a particular codec. Codecs are small so this should not be a big deal.
Success Chuck! Everything seemed to download and install ok last night. Thank you again for all your help!
You’re VERY welcome! All the best to you and all.
