Server Version#: 1.18.5.2309
Player Version#: 8.7.2.20952
Plex for android stops music playback (at the end of a song, next song does not start) when phone goes to sleep ? It does look this way I use Samsung S8 and when I wake the phone (without necessarily the need to unlock it) the playback resumes after a few seconds.
This is annoying and I dont want to disable phone sleep mode if that can help in order to save battery. Any solutions ? This really seems like a bug in the plex android mobile app.
Server Version: 1.20.3.3437
Player Version: 8.7.2.20952
I’m having this same problem on my Galaxy S10. I turned off battery optimization and it at least would play when the screen turned off, but it still stops playing after every 2 songs when I try to listen to an album.
Mh it stopped working again and i cannot convince the device to keep playing once the safe screen kicks in. Wonder how I got it working in the first place.
I’m running into the same issues. I’m finding that Plex for playing music on my Samsung Mobile device has really degraded over the past few months. I never had this many issues playing music, but now it stops playing for no reason, says playback failed. Can someone please look into these issues with playing music?
Ensuring “stay connected while asleep” is on (accessed from “settings” > “battery” > “more battery settings”) and excluding Plex from battery optimizer (accessed from “settings” > “apps” > “…” > “special access” > “battery optimization”) seems to have done the trick for me.
Thanks @ACurthoys, that is indeed a “buried” setting I had not noticed before. I just disabled Plex from this screen and will give it a go today. Huge thanks for the recommendation!
I originally entered this post. Effectively I’m on a Samsung Galaxy S8 and had to disable any kind of sleep/battery energy saving feature for Plex App to workaround the problem. Since then the problem disappeared.
I’m still trying to diagnose my specific issue. But I am pretty sure this is happening to me too. It’s VERY annoying. I can’t even press the play button on my lock screen. It ignores it. I have t kill the app, then it’s somehow running in the background as the app appears in the status bar and I have to kill that. Then relaunch the app.
I don’t have Tasker but that might fix things by preventing my screen from locking.
When playing video, the app prevents the screen from locking. Please just give us the option to do that with music!
I use the application when out for runs and having it just stop playing music is very annoying. I don’t want to stop running just to fix my phone.
